In need pics of 71 cuda brake/fuel routing pics
#1127425
12/04/11 02:31 PM
12/04/11 02:31 PM
Posts: 2,937 GA
roadrunninMark
GA
I need some pics for the brake line routing on a 71 barracuda/cuda as I am changing from drum to disc. I bought the 2 new valves - proportioning valve and the distribution valve along with the 2 piece front to rear brake line. Since I didn't have this before and the car was half apart when I bought it, I do not know where the the proportioning valve mounts, in which direction, and such. If someone could shoot some detailed pics for me of routing and all I would greatly appreciate it! Also if it isn't too much trouble, the same for the fuel lines, especially the ECS lines as they were missing. I bought them but I don't know if I will use em. Thanks again, can email me the pics at midairmark2@aol.com
Re: In need pics of 71 cuda brake/fuel routing pics
[Re: roadrunninMark]
#1127436
12/07/11 02:53 PM
12/07/11 02:53 PM
Posts: 2,368 White Plains, NY
VCODE
White Plains, NY
Mark, You should not be using the valve on the frame rail. Jan 70 it was put into the dist block under master cylinder. Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
#1127438
12/07/11 03:30 PM
12/07/11 03:30 PM
Posts: 2,937 GA
roadrunninMark
GA
Are these the valves I should need for non powered disc front/drum back? Or should I just have the one Bob shows?
#1127439
12/07/11 04:18 PM
12/07/11 04:18 PM
VCODE
White Plains, NY
Mark, I was just showing you that the dist block and prop valve how are made together.If you are changing to disc front you will need the metering one also. Don't be confused the metering block is a extra valve attached to the dist block.It is different then the prop valve. Early 70 E body w/disc had all 3 but after Jan 70 went to the 2 put together. Hope this helps Bob
