Page 3 of 10 1 2 3 4 5 9 10
Re: Junkyard D150 Progress [Re: hp383] #1125315
12/13/11 07:40 PM
12/13/11 07:40 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
hp383, I instlled the mounts and set the engine in; maybe the extra height will be better for header fitment???? I will post pix tonite of the engine in the frame. Thanks for your help
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125316
12/13/11 08:00 PM
12/13/11 08:00 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Here is a pix of the engine setting in the frame. I used my engine stand support and a piece of 36" rectangle tubing to support the rear.
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125317
12/13/11 08:02 PM
12/13/11 08:02 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Lots of room underneath the pan; here's a pix of the pass side using diesel engine mounts.
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125318
12/13/11 08:04 PM
12/13/11 08:04 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Driver's side
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125319
12/13/11 08:07 PM
12/13/11 08:07 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
And left front view. Click on the attachment to really get a closeup view on each of the pix.
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125320
12/13/11 09:15 PM
12/13/11 09:15 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
You need some paint on that oil pump, its starting to flash rust
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125321
12/13/11 09:19 PM
12/13/11 09:19 PM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
Ok, what are the "extra" bolts for at the bottom of the engine block. Just above the oil pan. looks to be 4 on each side.
Re: Junkyard D150 Progress [Re: hp383] #1125322
12/13/11 09:45 PM
12/13/11 09:45 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
My guess would be the main bearings are cross bolted, think 4 bolt mains, Hemi style. Two in the normal location, and two through the side of the block. Gene
Re: Junkyard D150 Progress [Re: poorboy] #1125323
12/13/11 10:01 PM
12/13/11 10:01 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
hp383, this is a cross bolted main block. A dodge dealer on the east coast was one of the ones ordered to close and they liquidated all their parts. I bought the MP (World) bare block for less than half price and built a 512 out of it. Had issues with the releif valve sticking when I ran it on a friend's dyno and had to change the pump out. I'll touch up the block before its all over with. LOL Do you think the extra little rise caused by the diesel mounts will help the header clearances??? It has about 8 dyno pulls and 500 road miles on it already. Friend couldn't afford the 67 Coronet with the motor so I pulled it and we put in a mild 440 and he is happy. And I will be happy; might take a while but the work keeps me occupied; better than sittin in the rockin chair
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125324
12/13/11 10:10 PM
12/13/11 10:10 PM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
Not sure how much the rise helps, but I installed a set of Flowtech headers (Had them installed with help of friends).
The tubes all clear, and nothing had to be dinged. The headers will still a pita to get in there. If doing it again, I would install the headers in the truck, then drop in the motor.
Re: Junkyard D150 Progress [Re: hp383] #1125325
12/14/11 11:31 PM
12/14/11 11:31 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Larry; As usual you do flawless work! Looks to nice to drive. Dave
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125326
12/15/11 04:57 AM
12/15/11 04:57 AM
Bismarck, ND USA
cageman Offline
cageman  Offline
Bismarck, ND USA
Boy that is a nice looking frame, where in ND are you from?
Re: Junkyard D150 Progress [Re: hp383] #1125327
12/15/11 07:17 AM
12/15/11 07:17 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Arent Bigblocks 2 and 4wd specific when it comes to headers?
Re: Junkyard D150 Progress [Re: 76dodgeboy] #1125328
12/15/11 12:17 PM
12/15/11 12:17 PM
scratchnfotraction Offline
my flow techs that listed for 2x and 4x4 did not fit on the 2x truck on driver side,beat 50% of #1 tube almost flat and still did not fit flowtech = junk
the passide will have the tubes moved over for the front drive shaft to move up and down with chassis/driveline flex.
I would go with hedmans that are BB 2x spicific,IMHO
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125329
12/17/11 05:21 PM
12/17/11 05:21 PM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
Larry,
Did you ever find a usable bellcrank? I got out to check the parts truck and the one on there still pivots. Not freely of course, but I can swing it by hand, so it's a good candidate for repairs. I might could get out there this weekend and get it if you want or you can come get it.
Mike
Re: Junkyard D150 Progress [Re: 1E2C] #1125330
12/17/11 06:01 PM
12/17/11 06:01 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
You have a PM Mike..
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125331
12/17/11 08:09 PM
12/17/11 08:09 PM
cross bolted mains
Indy aloony-um heads
click on attachment for close up...
thats looking awsome so far
Re: Junkyard D150 Progress [Re: scratchnfotraction] #1125332
12/17/11 08:29 PM
12/17/11 08:29 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Thanks Scratch; hey I think 1E2C has a p. brake bellcrank that moves and he is close to me.
Got a question about 727s will a standard long (18 3/8") tailshaft work in my frame? Or do I need a short shaft one? Thanks
Larry
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125333
12/17/11 08:53 PM
12/17/11 08:53 PM
yes a standerd long tail shaft 727 fits
center of trans mount bolts should be 7" from rear of trans case.
most short shafts have this same 7" distance and will work with the slip/spline drive shaft.
the BB 727 i have in my truck was from a 1 1/4 ton MH cassis,the center of mount bolts was 5"..I had to move my xmember foward 2" and build it from square stock and the lower support braces of the stock cross member.
it also used a early flat thin rubber trans mount like a 71 truck,the spedo was behind the mount and not in front so a stock xmember no worky.
that would be the only thing to watch for hunting,as long as the spaceing is 7" it bolts in.
glad you got the e-brake peice,i had no luck in the JY today for anything,nice walk in nice weather though
this 727 shorty was the first oddball one I have seen with the mount,speedo,huge 4 5/8 u-joint...the yoke did swap out to a 7260 though.
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125334
12/17/11 09:12 PM
12/17/11 09:12 PM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
They all came with the standard long tailshaft 727, I'm even using the original automatic driveshaft with my 833 setup since it's all the typical stuff. It starts to get strange with some of the heavy duty or 4WD stuff though.
