Page 1 of 10 1 2 3 9 10
Junkyard D150 Progress #1125275
12/01/11 09:43 PM
12/01/11 09:43 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
After removing the cab, bed, and front clip, I spent hours removing the surface rust on the frame. Was able to use the sandblaster at the local Air Base Hobby shop to blast the steering knuckles, rotors, strut rods, springs and various small items. Used Rustoleum semi gloss on the frame. Had the rotos turned, purchased rebuilt calipers, new pads, bearings, etc. Here are a few pix of my progress. Moparts members have really helped me out with parts and tech advice.
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125276
12/01/11 09:45 PM
12/01/11 09:45 PM
scratchnfotraction Offline
you have raised the bar in detail
very nice
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125277
12/01/11 09:46 PM
12/01/11 09:46 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Picture of the steering box brace that scratchin told me about.
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125278
12/01/11 09:49 PM
12/01/11 09:49 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Another pix of the passenger side; found a factory weld that let loose on one of the crossmembers that I will need to get welded before I finish up the driver's side
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125279
12/01/11 09:50 PM
12/01/11 09:50 PM
New York
jagrunt551 Offline
jagrunt551  Offline
New York
Looks very good !
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125280
12/01/11 09:51 PM
12/01/11 09:51 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Front half of the frame
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125281
12/01/11 09:58 PM
12/01/11 09:58 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Switched pans from a center to rear sump; not much room between the oil pickup and the crank throws (4.25" stroke; had to do a little repositioning to get a good 1/4".
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125282
12/01/11 10:01 PM
12/01/11 10:01 PM
now yur just showin off strokin it
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125283
12/01/11 10:01 PM
12/01/11 10:01 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Also installed the motor mount brackets; will have to decide what mounts to use as the 512 shakes a bit at idle (at least it did in the Coronet I had it in previously)
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125284
12/01/11 10:06 PM
12/01/11 10:06 PM
Round Rock,Tx
N
Nirvana Offline
Nirvana  Offline
N
Round Rock,Tx
Wow nice
87 D100 225 4 speed.
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125285
12/01/11 10:06 PM
12/01/11 10:06 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Thanks scratchfotraction; you have to do that once in a while
Anyway, it is fun and keeps this old man busy and out of trouble. What are you using for the rubber motor mounts? I am thinking that I will need something like a mag mount or a strut to limit the side to side movement of the engine. I heard ther are a few on the board denting their headers from the movement. One guy resorted to a front motor plate. I don't want to go that far though
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125286
12/01/11 10:31 PM
12/01/11 10:31 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Spiffy
get 1 of Creative Engine Swaps Torque limiter straps. I dont know if one is made for trucks but a B/E kit (shown) shoudnt be to hard to convert..
I am truckless..
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125287
12/01/11 10:32 PM
12/01/11 10:32 PM
I just got a set of the polyloc mounts from member Dragula(very cheap I may add,thanks Randy)
they look to be solid enuff,but I also used a pattern off of a set of elephant ears to make a steel driver side torque strap.
I will have the one side of a truck wp housing milled the thickness of the plate so nothing moves on the belt alinement.
then weld up a quik pin mount at the frame for it.
just need to have machine work done and it will have 1 elephant ear
you could nix the mounts and let the engine bracket sit down on the frame and bolt it in solid,it has enuff room on the pan and the holes line up
when I mocked mine up looking
Re: Junkyard D150 Progress [Re: scratchnfotraction] #1125288
12/01/11 11:09 PM
12/01/11 11:09 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Thanks guys for the ideas; I actually do have one of those torque limiter struts off of the Coronet that once the engine is in, I'll see if it will work. I could bolt it in solid but wonder about the vibes....it'll be a while before I am at that point so I have time to figure something out..
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125289
12/01/11 11:14 PM
12/01/11 11:14 PM
I have the card board pattern of the elephant ear if you want it to make one from alum or steel
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125290
12/02/11 12:25 PM
12/02/11 12:25 PM
Sparks, Nevada
MoparMike23 Offline
MoparMike23  Offline
Sparks, Nevada
That chassis looks great. If you blasted the spindles, you might wanna consider clear coating them to prevent them from rusting. I couldn't tell if you treated them or not.
Keep up the good work!!!
Mike
1969 Superbee 440-6
1977 D-150 Adventurer
2000 Jeep TJ
2018 Challenger Scat Pack Shaker
2019 Ram 2500 CTD
Re: Junkyard D150 Progress [Re: MoparMike23] #1125291
12/02/11 03:07 PM
12/02/11 03:07 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Thanks Mike, I clear-coated the inner and outer portion of the hub and the rest of the knuckle is ceramic coated flat gray.
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125292
12/02/11 05:21 PM
12/02/11 05:21 PM
Houston, Texas
Slant6pak Offline
Slant6pak  Offline
Houston, Texas
Please fill us in on that steering box brace...
I've been trying to figure out what I'm going to do on my Ramcharger.
2016 Challenger Scat Pack Shaker smile
1000 ci Brass Era Speedster project
Re: Junkyard D150 Progress [Re: Slant6pak] #1125293
12/02/11 05:36 PM
12/02/11 05:36 PM
it came stock on some trucks and it is repoped now also or a JY.
was a problem solver from the factory,the trucks like to crack the frame at the box bolt holes.
it will firm the steering right up,a swaybar up front is another good upgrade on the 2x trucks.
not sure where he got his,it looks new,but then agian everything he has done up looks new
Re: Junkyard D150 Progress [Re: scratchnfotraction] #1125294
12/02/11 05:45 PM
12/02/11 05:45 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Click on the Dodge Connection (sponsors on the site) They had them in stock for around $48.00
http://www.dodgeconnection.com/catalog/item/2901766/4541374.htm
