Re: 71 440/6...Cast in 7-69 ?????
[Re: THESHAKERPROJECT]
#1125017
12/01/11 05:29 PM
12/01/11 05:29 PM
Posts: 5,268 NY
70440+6bbl
NY
I would expect to find a E stamped on the top pad if it was a made in 69 mtr or would mopar just stamp a G on top of the E and put the mtor in a 71 car ?? I have been told ALL hemi blocks used in 71 cars were cast in 69 and have a 69 casting date on the side but I never knew a 71 car could have a cast in 69 B or RB block. Im trying to get a pic of the vin stamping.
Your block was cast in '69, but machined and assembled during the '71 MY, to be used in a '71 vehicle.
[Re: 70440+6bbl]
#1125018
12/01/11 05:33 PM
12/01/11 05:33 PM
Posts: 74,942 U.S.S.A.
JohnRR
U.S.S.A.
What he said.
Just because a block was cast does not mean it gets machined and assembled right after. That block could have been hanging around for any number of reasons.
[Re: kidmopar]
#1125019
12/01/11 05:35 PM
12/01/11 05:35 PM
Posts: 1,163 NORTHERN VA
THESHAKERPROJECT
NORTHERN VA
Sure! My 1971 "G" 440 was cast in 1969
......So you have a warrenty motor that has a G 440 stamped on the top pad and a cast date 69 on the side of the block and no vin. This car is a 71 sixpack mtr with a vin ,a G 440 stamped on the top pad but a 7/69 casting date on the block. Has anyone ever see this ?
#1125020
12/01/11 05:44 PM
12/01/11 05:44 PM
JohnRR
U.S.S.A.
A warranty engine would not be stamped with the MODEL year.
I'm not buying the WARRANTY claim of the engine above.
[Re: JohnRR]
#1125022
12/01/11 06:50 PM
12/01/11 06:50 PM
Posts: 1,169 Richmond, VA
rayztoy
Richmond, VA
John, Would a block stamped with an F or G, but NO VIN stamped be an over the counter parts department block or one the factory worker forgot to stamp? TIA Ray
#1125024
12/01/11 08:33 PM
12/01/11 08:33 PM
JohnRR
U.S.S.A.
Yeah, I was wonderin about that. Thought the top pad would have been blank or had a W stamped there. So anyone else have a real production 1971 sixpack num matching engin with a G 440 on the top pad and a 1969 casting date on the block ???
Are you not going to believe it is possible unless one person has one ?
I have seen a 340 with a mid 70 casting date and a 1973 VIN stamped on it.
[Re: rayztoy]
#1125025
12/01/11 08:38 PM
12/01/11 08:38 PM
JohnRR
U.S.S.A.
Over the counter would be stamped S in the model year spot if it were an over the counter long block assembly, S being service replacement ... UNLESS a full engine got pulled for some odd reason.
Short blocks wouldn't get stamped ... I think ... but would have the riveted tag on the side saying what the short assembly build number was for reference.
It is also possible that an engine just didn't get stamped, the lunch or end of shift bell rang and the guy dropped what he was doing and off he went ?
#1125028
12/02/11 12:31 AM
12/02/11 12:31 AM
JohnRR
U.S.S.A.
My 71 sixpack Challenger has a casting 7/70 and spd feb 71. Thats within 7 months ....Ok The block in question is in a car for sale and that why we want to be shure. Sounds like a 69 block ina 71 car is not really that unusual... Thanks.
As I said above there are 2 possible reasons , I would look closely ... IN PERSON ... at the ID pad and VIN pad BEFORE laying out the cash ....
[Re: shakerjoe]
#1125030
12/02/11 09:47 AM
12/02/11 09:47 AM
JohnRR
U.S.S.A.
my 71 BS23V1 - block cast 7/31/69 - engine pad stamp G 440 1 8 HP - spd 05/26/71...
We have a winner
[Re: JohnRR]
#1125031
12/02/11 06:53 PM
12/02/11 06:53 PM
Posts: 892 MA
steve70
MA
I have a numbers matching 1971 Charger R/T 440 4 barrel 4 speed
engine cast date 1-28-69 engine build date 8-31-70
1970 Challenger T/A 4 speed
