Zinc inner leafs?? #1124192
11/29/11 05:59 PM
11/29/11 05:59 PM
New York
rarefish Offline OP
rarefish  Offline OP
New York
What is the purpose of the zinc inner leafs installed between the springs? Can you still buy them? I bought a Mopar spring rebuild kit and it came with galvanized sheet metal for the inner leafs.
Re: Zinc inner leafs?? [Re: rarefish] #1124193
11/29/11 09:18 PM
11/29/11 09:18 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
it's a sliding point and is designed to reduce inner spring friction. back in the day leafs used to have sheet metal covers full of grease that you had to disassemble, clean and re-grease every so often. The zinc did away with that mess
Don't be the exception.
