wiper arm gasket and pivot seal? #1123215
11/28/11 09:36 AM
11/28/11 09:36 AM
PA
BTTG Offline OP
BTTG  Offline OP
PA
in my firewall gasket kit the wiper gasket and pivot seal bag includes some butyl rope caulk. where do i use this? between the cowl and the top of the pivot seals would be my guess.....but that would be a guess. could also argue that the pivot seal should form a good barrier at the cowl and the caulk would not be needed?
Re: wiper arm gasket and pivot seal? [Re: BTTG] #1123216
11/28/11 05:18 PM
11/28/11 05:18 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
You'd want to use it where the pivots bolt to the cowl - in conjunction with the foam gasket for extra insurance. Did you mod the pivot with a zerk too?
Re: wiper arm gasket and pivot seal? [Re: 70Duster440] #1123217
11/28/11 06:19 PM
11/28/11 06:19 PM
PA
BTTG Offline OP
BTTG  Offline OP
PA
no zerks added. from the dust (created by the gaskets/seals) i would guess this is the first time these have been unbolted from the car.....no observed leaks previously.
Re: wiper arm gasket and pivot seal? [Re: BTTG] #1123218
11/29/11 01:20 AM
11/29/11 01:20 AM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
It's an optional step that offers: Improved lubrication, longer life, and extra insurance against leaks. They're pot-metal castings so it doesn’t take much to drill. You can feel the bit break through into some space around the pivot shaft. Just be sure to use the proper size bit for the press fit zerk.
