Best filler for tail light lens resto?? #1122096
11/26/11 10:43 PM
11/26/11 10:43 PM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
I have cracks in my tail light lenses and would like to know what is a good filler for light surface cracks? I'm restoring them for my 71 Duster 340. Its cracked in an area that gets painted black. So what works good? Should I polish them first then fill or vice versa?
Re: Best filler for tail light lens resto?? [Re: NV69B7RR] #1122097
11/27/11 02:21 AM
11/27/11 02:21 AM
Mississippi
lahatte Offline
lahatte  Offline
Mississippi
Since it's a painted area, you might look at Plastifix.
Regarding polishing, I would think, repair the cracks, polish, then paint where required.
Re: Best filler for tail light lens resto?? [Re: lahatte] #1122098
11/27/11 02:34 AM
11/27/11 02:34 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I agree on the plastifix in the painted areas.
If repairing a clear or colored lens in the visible areas is pretty much impossible. There are glues and products out there to glue them together etc. but most are for patching stuff together short term, not meant for "restoration" type repairs, most if not all of them will fail over time due to the hard/heat/chemical resistant properties of the thermoplastic that tail lights are made from not allowing a good bond in the first place. Even if they do work you'll always see the repairs. I'd suggest finding a better used lens to start with if you want to skip the $350 NOS examples on ebay/ 70/71 Duster lenses in good used condition are pretty common and not usually real expensive, they tend to have a pretty high degree of survivability.
Re: Best filler for tail light lens resto?? [Re: ScottSmith_Harms] #1122099
11/27/11 03:05 AM
11/27/11 03:05 AM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
I'll try that. The cracks are only where the blackout sections are, the illuminated parts are crack free. They should turn out good.
