1972 Barracuda frame dimensions needed #1120939
11/24/11 11:00 PM
11/24/11 11:00 PM
Connecticut
biginchmotor Offline OP
Connecticut
Can someone help me out with the factory frame dimensions for a 72 Barracuda? Need something to bring with me to the body shop to check out the frame. Thanks John.
Re: 1972 Barracuda frame dimensions needed [Re: biginchmotor] #1120940
11/25/11 03:47 AM
11/25/11 03:47 AM
Washington
19cuda73 Offline
19cuda73  Offline
Washington
Bought mine off ebay will scan a photo of it and post it in the morning for you. I believe a 73 is the same.
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: 1972 Barracuda frame dimensions needed [Re: 19cuda73] #1120941
11/25/11 02:59 PM
11/25/11 02:59 PM
NORTHERN CA
HUSTLESTUFF Offline
HUSTLESTUFF  Offline
NORTHERN CA
They are in the field service manual(FSM) in the body section, separate book for 72. Mike
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL
RIP UN
Re: 1972 Barracuda frame dimensions needed [Re: HUSTLESTUFF] #1120942
11/25/11 03:11 PM
11/25/11 03:11 PM
Wisconsin
Aero426 Offline
Aero426  Offline
Wisconsin
You have a PM.
Re: 1972 Barracuda frame dimensions needed [Re: biginchmotor] #1120943
11/25/11 07:56 PM
11/25/11 07:56 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Here's the 74 frame chart....
Re: 1972 Barracuda frame dimensions needed [Re: screamindriver] #1120944
11/25/11 09:16 PM
11/25/11 09:16 PM
Washington
19cuda73 Offline
19cuda73  Offline
Washington
I have one they use at the frame shops but it is to big of a file to put on Moparts can you pm me your email.?
Dennis
1972 Corvette
Re: 1972 Barracuda frame dimensions needed [Re: 19cuda73] #1120945
11/26/11 02:49 AM
11/26/11 02:49 AM
Washington
19cuda73 Offline
19cuda73  Offline
Washington
Here is the sheet the frame guy used on my cuda when it was on the frame bench. Not sure if 72 is the same but hope it works
Dennis
1972 Corvette
Re: 1972 Barracuda frame dimensions needed [Re: 19cuda73] #1120946
11/26/11 10:36 AM
11/26/11 10:36 AM
Connecticut
Connecticut
Thanks for the help with the frame chart. Dennis, thanks for the drawing, it is great. John.
Re: 1972 Barracuda frame dimensions needed [Re: biginchmotor] #1120947
11/26/11 03:10 PM
11/26/11 03:10 PM
Wisconsin
Aero426 Offline
Aero426  Offline
Wisconsin
72 & 73 frame charts are the same. The last one posted is the easiest one to use.
