1970 - 1971 Mopar Brake Tube Tee Autopsy
#1120721
11/24/11 05:23 PM
11/24/11 05:23 PM
Posts: 32 Virginia, USA
sah62
Virginia, USA
I just finished writing an article that describes how to disassemble the brake tube tee and pressure differential warning switch that was used on 1970 and 1971 Mopars (B, J, R, and W-bodies) equipped with drum brakes. Here's a link to the article: https://www.musclecarresearch.com/1970-71-mopar-brake-tube-tee-autopsyI'd appreciate any insights, additions, or corrections to make the article more useful. I know that a similar-looking part was used in earlier model years. Was this valve used on any other vehicles? Is anybody interested in a seal and spring kit to rebuild valves like this?
Scott Hollenbeck
Administrator, Mustang 428 Cobra Jet Registry
Owner, Muscle Car Research LLC
1970 Ford Mustang Mach 1
2006 Dodge Charger SRT8
1995 Chevrolet Impala SS
Re: 1970 - 1971 Mopar Brake Tube Tee Autopsy
[Re: JulesdaWiperman]
#1120725
11/24/11 08:43 PM
11/24/11 08:43 PM
sah62
Virginia, USA
Thanks for the comments! I wasn't sure about the need to remove the seat until after I had it all apart and saw the internal parts. You're right, though, compressed air could do the trick. Quote:
It's very well written as a guide. Would like to see the restoration part.
Are you planning on removing the bracket to replate it?
I'll figure out what to do with the bracket once I have it all cleaned up. The plating I can see under the grime looks pretty decent, but it will probably have to be re-done to have something that's worth putting on a restored car.
I reall would like to see a re-build kit made that contains the o-ring seals and all other seals needed. When putting the valve together again, do you use any type of sealent on the top and bottom ?
Sealants aren't needed to put the parts back together. With new o-rings and good brake line fittings there shouldn't be any leaks.
I'll look into the cost to come up with a seal kit. I'm not yet sure if it makes sense to include the springs - if they're not rusted they can probably just be cleaned and re-used. Even though repros are available I'm sure there are people who want to rebuild these parts to preserve the date codes.
Scott Hollenbeck
[Re: sah62]
#1120726
11/24/11 08:48 PM
11/24/11 08:48 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
There are known issues with the Chinese Repo valves... Get a seal kit together & you'll make some guys restoring these cars very happy...
[Re: sah62]
#1120729
11/26/11 12:40 PM
11/26/11 12:40 PM
sah62
Virginia, USA
Has anyone ever seen one of these parts with a hex head plug like the one in this picture? Is the plug original or a replacement?
Scott Hollenbeck
[Re: sah62]
#1120730
11/26/11 02:23 PM
11/26/11 02:23 PM
Posts: 1,163 NORTHERN VA
THESHAKERPROJECT
NORTHERN VA
the brass hex plug on the far rt in you pic is orig. I have the same valve on my car. Look at Jules pic above. Its the same plug.
[Re: THESHAKERPROJECT]
#1120733
11/27/11 01:27 PM
11/27/11 01:27 PM
sah62
Virginia, USA
Thanks for the insights! I've updated the article to note the different plugs and to note that you can avoid removing the seat if you have access to a compressor.
Scott Hollenbeck
[Re: sah62]
#1120734
11/28/11 01:18 PM
11/28/11 01:18 PM
My end plug is stripped out. Is there anyone or anyplace that I can get a new end plug?
