Page 4 of 8 1 2 3 4 5 6 7 8
Re: I知 building a 3-stall garage with living space above [Re: 1fastsixpack] #1120461
12/02/11 09:11 PM
12/02/11 09:11 PM
1fastsixpack Offline OP
#2
Re: I知 building a 3-stall garage with living space above [Re: 1fastsixpack] #1120462
12/02/11 09:11 PM
12/02/11 09:11 PM
#3
Re: I知 building a 3-stall garage with living space above [Re: 1fastsixpack] #1120463
12/02/11 09:12 PM
12/02/11 09:12 PM
#4
Re: I知 building a 3-stall garage with living space above [Re: 1fastsixpack] #1120464
12/02/11 09:17 PM
12/02/11 09:17 PM
The builders lost control of one of their ladders during a wind storm before it fell into our camper! Their insurance company will be getting a bill!
Re: I知 building a 3-stall garage with living space above [Re: 1fastsixpack] #1120465
12/02/11 09:28 PM
12/02/11 09:28 PM
The Hemi leaving camp with our camper. The Hemi is one pulling machine! However, it sucked gas on the way home like a thirsty camel drinking water.
Re: I知 building a 3-stall garage with living space above [Re: 1fastsixpack] #1120466
12/02/11 11:56 PM
12/02/11 11:56 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
Lookin good! You better get some sealer over that hole they knocked in your camper if you haven't already. I keep a small roll of Eternabond in our camper for just such emergencies.
Re: I知 building a 3-stall garage with living space above [Re: JDMopar] #1120467
12/03/11 09:03 AM
12/03/11 09:03 AM
Great idea!
I知 hauling our camper to the place we bought from this morning. They need to replace the awning I broke this spring when I decided to empty the water that had collected on it during a heavy rain by releasing a support arm to the awning to lower one side. Not a good move! There must have been 800lbs of water that I couldn稚 hold. The support broke free from my hands and slammed against the trailer. The long aluminum tube that the awning rolls around broke in half. I did $1300 dollars of damage in less than a second! My insurance company paid, but I still had to pay my $600 dollar deductible. Now I need to get a bid for the ladder damage and have them fix that. Thankfully the contractor痴 insurance company is getting this bill. The damaged panels have part of the stripes to the side graphics on them. I bet the stripe package alone is big money. Not to mention the labor for changing two panels.
Re: I知 building a 3-stall garage with living space above [Re: 1fastsixpack] #1120468
12/04/11 02:05 PM
12/04/11 02:05 PM
JDMopar Offline
JDMopar  Offline
Yep...labor for those 2 panels won't be cheap, cause they'll have to remove every panel from the top down to fix those 2! At least they can put the labor to R&R the awning attachments on the bill with the siding. That will save you a few bucks with the deductible. Good luck with it.
Re: I知 building a 3-stall garage with living space above [Re: JDMopar] #1120469
12/06/11 07:29 PM
12/06/11 07:29 PM
You were right! The rv service department wrote up an estimate to repair the ladder damage, and it ended up being over $1,700 dollars.
Sadly, I also found out the roof of our 2007 camper had been leaking. And apparently for quite some time (news to us) since some of the plywood under the rubber roof liner has rotted. They told me $700 to $900 dollars to fix that mess.
Re: I知 building a 3-stall garage with living space above [Re: 1fastsixpack] #1120470
12/06/11 07:31 PM
12/06/11 07:31 PM
Fresh pic 1
Re: I知 building a 3-stall garage with living space above [Re: 1fastsixpack] #1120471
12/06/11 07:32 PM
12/06/11 07:32 PM
Fresh Pic 2
Re: I知 building a 3-stall garage with living space above [Re: 1fastsixpack] #1120472
12/06/11 07:34 PM
12/06/11 07:34 PM
Fresh pic 3
Re: I知 building a 3-stall garage with living space above [Re: 1fastsixpack] #1120473
12/06/11 11:55 PM
12/06/11 11:55 PM
JDMopar Offline
JDMopar  Offline
Dang....hate that about the roof! The rubber must still be good and can be saved. We had to put a new rubber roof and 2 pieces of plywood on our 5th wheel, and it was $3200. On a happier note...it looks like your siding folks are rockin on!
Re: I知 building a 3-stall garage with living space above [Re: JDMopar] #1120474
12/10/11 07:28 PM
12/10/11 07:28 PM
Things are finally starting to come together on our up-north project. Last week, the furnace and a/c were finished. The gas company delivered and installed our LP tank. The power company trenched in the power and hooked it up to the cottage/garage. In addition, the water line was buried from the cottage/garage to the well before being hooked up. And the vinyl siding is about done. Lots of wiring was also completed. This week, the rough plumbing will hopefully be finished, and the chimney for a woodstove should be done. Insulation and drywall will be going in soon!
Re: I知 building a 3-stall garage with living space above [Re: 1fastsixpack] #1120475
12/10/11 07:37 PM
12/10/11 07:37 PM
places
79powerwagon Offline
places
That is really nicely done!
Re: I知 building a 3-stall garage with living space above [Re: 1fastsixpack] #1120476
12/24/11 12:55 PM
12/24/11 12:55 PM
The siding crew finally finshed siding and trimming yesterday!
Pic 1
Re: I知 building a 3-stall garage with living space above [Re: 1fastsixpack] #1120477
12/24/11 12:57 PM
12/24/11 12:57 PM
pic 2
Re: I知 building a 3-stall garage with living space above [Re: 1fastsixpack] #1120478
12/24/11 12:58 PM
12/24/11 12:58 PM
pic 3
Re: I知 building a 3-stall garage with living space above [Re: 1fastsixpack] #1120479
12/24/11 12:59 PM
12/24/11 12:59 PM
pic 4
Re: I知 building a 3-stall garage with living space above [Re: 1fastsixpack] #1120480
12/24/11 01:01 PM
12/24/11 01:01 PM
pic 5
