Any MSD Street Fire users? #1120091
11/23/11 10:25 PM
11/23/11 10:25 PM
MI
68shifter Offline OP
MI
Just curious if anyone has used a street fire ignition box. Debating between that and a 6al
68' Barracuda (4 speed) 64' Savoy (4 speed) 65' Satellite (girl tranny)
Re: Any MSD Street Fire users? [Re: 68shifter] #1120092
11/25/11 12:23 AM
11/25/11 12:23 AM
Colorado
68FuryIIIColo Offline
Colorado
Depends on what you are using the car for. I have run the Street Fire ignitions on a Datsun 240z street car and my 99 Dakota. They work just like the 6al for street applications. The 6AL is race tech...you need to be on the track pushing it hard to get the full capabilities. The price on the street fire is nice too for a street application.
Re: Any MSD Street Fire users? [Re: 68FuryIIIColo] #1120093
11/25/11 12:29 AM
11/25/11 12:29 AM
MI
MI
Thanks.
Yep just strictly street use with a mild 440. Thought for the price worth a shot, but if sketchy a 6AL isnt much more.
Re: Any MSD Street Fire users? [Re: 68shifter] #1120094
11/25/11 04:26 PM
11/25/11 04:26 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
that looks to be a pretty nice unit. less spark energy than the 6 series but i doubt with a street driven car there would be a noticable difference. rev limit too, i like that.
Re: Any MSD Street Fire users? [Re: 68shifter] #1120095
12/01/11 01:09 PM
12/01/11 01:09 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
I am about to pull the trigger on one. Is anyone running one yet?
Re: Any MSD Street Fire users? [Re: YO7_A66] #1120096
12/01/11 01:12 PM
12/01/11 01:12 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
do it but please report back!
Re: Any MSD Street Fire users? [Re: mikemee1331] #1120097
12/01/11 10:23 PM
12/01/11 10:23 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
You were supposed to play devils advocate and talk me out of it!
I should have one tomorrow but I won't be able to give any driving opinions until Spring. I do hope to have it wired in and started up this weekend though.
Re: Any MSD Street Fire users? [Re: YO7_A66] #1120098
12/02/11 09:43 AM
12/02/11 09:43 AM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
I have a quick question on the wiring for the MSD 5520 unit.
I am currently running a voltage gauge that is connected to the "+" side of the coil and it reads the average coil voltage and it works fine. The instructions for the MSD unit say that the ONLY wire to be connected to the "+" side of the coil is the orange wire. Will I have any issues if I wire in my voltage gauge to the orange wire ("+") ?
Re: Any MSD Street Fire users? [Re: YO7_A66] #1120099
12/02/11 11:18 AM
12/02/11 11:18 AM
dogdays Offline
dogdays  Offline
Absolutely. Do not do it.
The Street Fire (I suspect it's made in China to compete with the Summit Chinese MSD copies) is a Capacitive Discharge ignition. When the capacitor discharges into the coil it sends a spike of 435 volts. To get multiple sparks it sends multiple spikes. That should either fry or really confuse your voltmeter.
R.
Re: Any MSD Street Fire users? [Re: dogdays] #1120100
12/02/11 11:22 AM
12/02/11 11:22 AM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
Got it, thanks.
Note: The Street Fire box is built in the US, but the Street Fire coil is not. I got that info from the MSD tech web sight.
Re: Any MSD Street Fire users? [Re: YO7_A66] #1120101
12/02/11 11:51 AM
12/02/11 11:51 AM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
The MSD instructions say that the Street Fire box can be used with any stock coil or any stock aftermarket replacement coil. I assume that my FBO 12v coil can handle this box. Any comments are appreciated.
Thank you.
Re: Any MSD Street Fire users? [Re: YO7_A66] #1120102
12/02/11 11:54 AM
12/02/11 11:54 AM
dogdays Offline
dogdays  Offline
I'm sure it can handle the voltage because it is applied in short spikes and because the other side of the coil has to be able to handle 45K volts. I have used the MSD 6A on my Jacobs chrome coil which looks like a stock oil-filled cylindrical coil for about a year now and no problems. Also consider that probably millions of CD ignitions are out there most using the stock coil. So no worries.
R.
Re: Any MSD Street Fire users? [Re: dogdays] #1120103
12/02/11 12:21 PM
12/02/11 12:21 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
Good point, thanks.
Another one:
On the attached schematic, the RED wire is shown to plug into the "original coil "+" terminal" which is the "run" blue wire. I am assuming that I need to also splice in the "crank" brown wire into this splice too?
Thanks again.
Re: Any MSD Street Fire users? [Re: YO7_A66] #1120104
12/02/11 01:04 PM
12/02/11 01:04 PM
dogdays Offline
dogdays  Offline
I don't know. If the blue wire has power in start mode you don't. If it only has power after you release the key from starting then it does. I'm thinking the blue wire is hot whenever the key is on but I can't remember for sure.
R.
Re: Any MSD Street Fire users? [Re: dogdays] #1120105
12/02/11 01:58 PM
12/02/11 01:58 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
I show that the blue "run" wire has 12v only on run and the brown "crank" wire only has 12v during crank. I will splice these together for the RED wire. I can splice my existing voltmeter in with the RED wire for my ignition voltage reference from inside of the car to see both cranking voltage and run voltage.
Another one:
My current spark plug gap is the standard .035", should I open up the gap? If so to what and why?
Street Fire or 6AL [Re: 68shifter] #1120106
12/02/11 02:03 PM
12/02/11 02:03 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
This post is timely.
So I’m thinking about an ignition upgrade on the Road Runner. Currently running a stock type electronic ignition set-up with a recurved distributor. It’s probably overmatched against my fat cammed small block stroker. I was just going to put a better box on there but I think a multi-spark is in order to improve its manners around town lugging around in traffic and keep the plugs cleaner.
The car is 99% street, and while I haven’t put it on the track yet, I’ll do some fun runs when the opportunity presents.
I’m debating between the value priced street oriented Street Fire, or the tried and true, but significantly more expensive and more race oriented 6AL.
One thing I really like about the Street Fire is the compact size. It’s barely bigger than the stock box. There is also a new 6AL-2 which is about the same size, but with a two step limiter and a significantly higher price tag.
Lots of feedback out there on 6ALs, so I’m most interested in hearing from folks running a Street Fire, and what its limits are.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: Street Fire or 6AL [Re: 471Magnum] #1120107
12/02/11 02:16 PM
12/02/11 02:16 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
I have had a tough time finding the information too. From what I have found out so far, the Street fire box is made in the US and it is compatible with the magnetic pickups in our stock type Chrysler distributors (per the schematic). This box has an output for a tach and it is a bit smaller and it comes in black. The box will fire a stock or stock aftermarket coil so there is no special coil to buy. It has adjustable external rev limiter (one knob for 1000 and one knob for 100rpms). It has a LED that shows solid when the engine is running and the ignition has enough voltage (9-18v) to run correctly. Under 9 volts, the LED will flash to show low voltage. I have read that it will trigger as low as 7 volts but they recommend feeding it with 10-18v. I have found pricing from $120-$239 depending on where you buy it, but mostly $139-$159.00. I am having a tough time finding people running this box on the web so I thought that I would try our sight.
This box appears to be a good performance upgrade for the stock Mopar "type" ignition ECU. But we don't know how reliable it is yet.
Re: Street Fire or 6AL [Re: YO7_A66] #1120108
12/02/11 03:21 PM
12/02/11 03:21 PM
Colorado
Colorado
I have a MSD Street Fire New for sale on Craigslist I also have a MSD Blaster SS coil to go with it. Send me a PM or email to mguzinski@gmail.com I know it's not the forum to list stuff for sale but...
I have run these before and they install pretty much like any MSD ignition. Here is the MSD site and you can download the Installation PDF on it too: http://www.msdignition.com/Products/Ignitions/Daily_Driver/5520_-_Street_Fire_Ignition.aspx
They work real well on street cars. I don't race so I'm not sure how they work on the 1/4 Mile. I'm guessing just fine.
Re: Street Fire or 6AL [Re: 68FuryIIIColo] #1120109
12/02/11 07:04 PM
12/02/11 07:04 PM
dogdays Offline
dogdays  Offline
They have about 2/3 the total spark energy of the 6A. I looked through everything on their website and did not find a single "made in USA" brag. They do say it was designed in the USA which sounds to me like it's built overseas.
If small size is your bag, the Accel 300+ is digital, small, has dial rev limiter, and I have more than 150K miles on one without a hiccup. It specs with the 6A but I believe has lower current draw. Most come with matching coils and I have bought 3 so far on the 'bay for $120 or less and they were new.
Do what you want. Good Luck!
R.
Re: Any MSD Street Fire users? [Re: dogdays] #1120110
12/02/11 08:06 PM
12/02/11 08:06 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
R.
it won't fry the meter.......... but do keep in mind that your tach may not work with a 'tach box'. also SOME dial back timing guns have a problem with jittery flashes. i would suggest not buying used, but thats just me.........
