Has anybody SEEN or USED a Hughes ported intake? #1119767
11/23/11 02:10 PM
11/23/11 02:10 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
Got pictures?
Got results?
When I posted a similar question sometime back, only one person had any experience and IIRC that intake showed no gains until the combination was switched from gas to alcohol.
Re: Has anybody SEEN or USED a Hughes ported intake? [Re: BradH] #1119768
11/23/11 02:12 PM
11/23/11 02:12 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
what engine, what intake?
Re: Has anybody SEEN or USED a Hughes ported intake? [Re: RodStRace] #1119769
11/23/11 02:19 PM
11/23/11 02:19 PM
BradH Offline OP
BradH  Offline OP
IIRC, the one person that had one was using their ported Super Victor on a stroker big-block.
I'd be interested in seeing examples of their work and hearing about any quantifiable results for anything they've done, although 440-type builds w/ single-plane intakes would be more applicable to my usage.
Re: Has anybody SEEN or USED a Hughes ported intake? [Re: BradH] #1119770
11/23/11 03:00 PM
11/23/11 03:00 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I had Hughes do a smallblock Super Victor for me and with a stage 2 "deep port match" saw a slight improvement across the range, but not quite as good as the Indy intake, I feel with a max porting it would equal and possibly exceed what the indy can do, it appears they did a nice job, just need to take it a step further and see what it does.
Re: Has anybody SEEN or USED a Hughes ported intake? [Re: dartman366] #1119771
11/23/11 03:15 PM
11/23/11 03:15 PM
BradH Offline OP
BradH  Offline OP
... a stage 2 "deep port match" ...
Their web site says they have a "Deep Port Match", a Stage 1 and a Stage 2 (most extensive work). Which one did you have done?
Re: Has anybody SEEN or USED a Hughes ported intake? [Re: BradH] #1119772
11/23/11 03:45 PM
11/23/11 03:45 PM
IL. Jerseyville
jg309 Offline
jg309  Offline
IL. Jerseyville
got the first one done by dave,s/b, m1,dave done the whole engine,brodx heads,2.02s/s ints.,1.60s/s rockersthat were set to corect dim.ported/polished,&cc(42cc),engine was a 360,.030 over,offset ground crank,6.20x2.00 rods,on chassie dino engine made 645hp, if anyones interested thes heads,& intake are for sale, $2000 for all+ freight, these heads take standard exhaust, if intrested call6188061564
Re: Has anybody SEEN or USED a Hughes ported intake? [Re: BradH] #1119773
11/23/11 03:58 PM
11/23/11 03:58 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
OOOP's sorry it was a stage 1,,got to fix these fat fingers.
Re: Has anybody SEEN or USED a Hughes ported intake? [Re: jg309] #1119774
11/23/11 04:20 PM
11/23/11 04:20 PM
BradH Offline OP
BradH  Offline OP
... thes heads,& intake are for sale, $2000 for all+ freight, these heads take standard exhaust, if intrested call6188061564
Perhaps the Race Parts For Sale section of this web site would be more appropriate for your reply...
