Re: A little Engine Progress on the 408 for my Cuda
[Re: Dragula]
#1119461
11/22/11 09:59 PM
11/22/11 09:59 PM
Posts: 20,622 in a cattle trailer down by th...
Guitar Jones
I used that girdle also. I don't know that it will do any good but it can't hurt. Did you get the W5's?
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: racerx]
#1119463
11/22/11 11:35 PM
11/22/11 11:35 PM
Guitar Jones
Cool who's girdles that?
Looks exactly like the Hughes piece I used. I had to chamfer the notches for rod clearance on mine using the H beams.
[Re: Guitar Jones]
#1119464
11/23/11 09:33 AM
11/23/11 09:33 AM
Posts: 12,383 Taxes & Virus's R-US, NY
Dragula
Hughes girdle. Ties everything togather, so I hope its worth it for the money...Still beats spending $2800 for an R3 if your not going to build an all out engine.
And the guy selling the W5's is back pedeling a little now. I called him for more info on them and to discuss what comes with them, which generation they are, and where he got them from. For the difference in flow numbers, my cam really doesn't really take advantage of it and mine flow pretty close, so I don't see a big advantage to going to them..Valves on both my W2's and his W5's are the same sizes, and my flow numbers are close enough for what I am doing to stay where I am at, we will see. My heads already have the valve job done and are all set and ready to install. Decked a couple thou off of them for flatness, replaced the guides, and gave them a good going thru.
They look awesome, and I know, even with the loss of the compression switching to pump fuel, this engine may still make the same horse power. We found enough issues to gain some of the compression loss back in other areas, so we will see.
