Re: 2.25" R3 main seal
[Re: 340_Dart]
#1119442
11/22/11 10:10 PM
11/22/11 10:10 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Seriously doubt it.
You probably have a Signal brand seal. Can't imagine one going bad. Is it a big split peice of rubber with an O-ring around it. Post a picture maybe we can help you out.
My block uses a Signal seal due to the better sealing properties over a standard lip seal. The block is specialy cut for this and can not be changed back.
Leon
[Re: 340_Dart]
#1119444
11/22/11 10:29 PM
11/22/11 10:29 PM
Leon441
Lynchburg, VA
You need the width of the seal, the OD and ID and I think CV Products can sell you the seal. I have an extra as I replaced mine once. But, it was not hurt. I suspect the same seal is used on the R5 but, I don't know.
Leon
