2.25" R3 main seal #1119441
11/22/11 09:14 PM
11/22/11 09:14 PM
Maryland
340_Dart Offline OP
340_Dart  Offline OP
Maryland
I have a R3 with 2.25"(Ford) mains that i need a rear main seal for. What seal do they use? I haven't done any real research, but i assume it"ll use either a standard 340/360 seal or a 302 ford seal. Anyone?
Re: 2.25" R3 main seal [Re: 340_Dart] #1119442
11/22/11 10:10 PM
11/22/11 10:10 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Seriously doubt it.
You probably have a Signal brand seal. Can't imagine one going bad. Is it a big split peice of rubber with an O-ring around it. Post a picture maybe we can help you out.
My block uses a Signal seal due to the better sealing properties over a standard lip seal. The block is specialy cut for this and can not be changed back.
Leon
Re: 2.25" R3 main seal [Re: Leon441] #1119443
11/22/11 10:20 PM
11/22/11 10:20 PM
Maryland
340_Dart Offline OP
340_Dart  Offline OP
Maryland
Leon,
Yes, the seal out of my block had the rubber o-ring around it. I wasn't sure if this was a R3 thing or not. I had the motor apart going over things and figured i'd replace it. Are replacements easy to get?
Re: 2.25" R3 main seal [Re: 340_Dart] #1119444
11/22/11 10:29 PM
11/22/11 10:29 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
You need the width of the seal, the OD and ID and I think CV Products can sell you the seal. I have an extra as I replaced mine once. But, it was not hurt. I suspect the same seal is used on the R5 but, I don't know.
Leon
Re: 2.25" R3 main seal [Re: Leon441] #1119445
11/22/11 11:03 PM
11/22/11 11:03 PM
Maryland
340_Dart Offline OP
340_Dart  Offline OP
Maryland
Thanks for the information Leon
Re: 2.25" R3 main seal [Re: 340_Dart] #1119446
11/22/11 11:33 PM
11/22/11 11:33 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Looking for 9's in that bad boy this year Andy ? Hey you and the family have a great Thanksgiving. Ron
Re: 2.25" R3 main seal [Re: 383man] #1119447
11/23/11 12:03 AM
11/23/11 12:03 AM
Maryland
340_Dart Offline OP
340_Dart  Offline OP
Maryland
Eventually Ron, Eventually This W8 motor is a project i've had for 2 years that i'm finally getting around to doing something with. I hope you have a good Thanksgiving also!
Re: 2.25" R3 main seal [Re: 340_Dart] #1119448
11/23/11 02:18 AM
11/23/11 02:18 AM
AndyF Offline
AndyF  Offline
See if Tri-Tec has a seal for it. They make the good seals for dry sump motors.
