Re: K-FRAME PAINT???
[Re: Challenger 1]
#1119203
11/22/11 04:01 PM
11/22/11 04:01 PM
Posts: 74,948 U.S.S.A.
JohnRR
U.S.S.A.
Thanks, it's a semi gloss I guess.
Yes semigloss , holds up well and you can get decent results out of the can.
NAPA also sells a chassis black paint I had good results with.
[Re: cogen80]
#1119205
11/22/11 05:59 PM
11/22/11 05:59 PM
Posts: 21,397 It's a dry heat
gtx6970
It's a dry heat
i would powder coat it.
if 100% OE correctnes is not a concern this the way I would go.
[Re: gtx6970]
#1119206
11/22/11 06:17 PM
11/22/11 06:17 PM
Posts: 6,224 JERSEY
RJS
JERSEY
if 100% OE correctness is not a concern this the way I would go.
The OP is asking about spray cans so I doubt 100% OE is on his mind. Powder coat in 45% black and call it a day.
[Re: Challenger 1]
#1119209
11/22/11 10:18 PM
11/22/11 10:18 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Chassis black from Eastwood has proven to be a very durable paint out of a spray can for me.
I've used thier Extreme chassis black a bunch of times now and am very happy with it.
[Re: OzHemi]
#1119211
11/22/11 10:34 PM
11/22/11 10:34 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
I used the Krylon Epoxy paint on the 8 3/4 that I put in my 81 shorty 10 years ago.. came out real nice and still looks good today...
I am truckless..
[Re: Labratt]
#1119212
11/22/11 10:36 PM
11/22/11 10:36 PM
OzHemi
Garden Grove, CA
painting the engine block BLACK!
Orange 8 qt. oil pan..
orange M-1 intake manifold
Oh, and nice thing about the chassis paint, if you ever do scratch it (not easy to do!) or what not...you can always touch it up...
[Re: Labratt]
#1119213
11/22/11 11:08 PM
11/22/11 11:08 PM
Posts: 1,151 Cruising!
QuickDodge
Cruising!
Alkyld enamels, such as Rustoluem, two biggest faults are chalking due to UV light exposure (from the sun, etc.) and chemical resistance. Adding some hardener will increase the chemical resistance considerably. Parts underneath the car receive minimal UV light exposure, so Rustoleum with some hardener added should hold up well. This type of finish would be acceptable for a summer time week-end car.
Obviously, a person could spend more money and use an epoxy primer and urethane paint or power coat chassis parts. These are superior coatings. I would seriously consider these finishes for vehicles driven on salt treated roads.
On a vehicle which is driven, any chassis paint or coating will be chipped and scratched over time. So a finish which can be easily repaired is usually a good idea for a frequently driven vehicle.
[Re: QuickDodge]
#1119214
11/22/11 11:12 PM
11/22/11 11:12 PM
Posts: 4,027 Dearborn Hts, MI
Sledge_57
Dearborn Hts, MI
Powder Coat maybe? I know a guy if you're interested Randy.
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
