offset head dowels #1118794
11/21/11 11:12 PM
11/21/11 11:12 PM
Fredericksburg Va
P
plycuda Offline OP
plycuda  Offline OP
P
Fredericksburg Va
anyone use these. It says it moves the head up for better intake valve flow.
Re: offset head dowels [Re: plycuda] #1118795
11/21/11 11:22 PM
11/21/11 11:22 PM
Delray beach, Florida
P
Performance Only Offline
P
port match the intake instead.
machine shop owner and engine builder
Re: offset head dowels [Re: Performance Only] #1118796
11/21/11 11:36 PM
11/21/11 11:36 PM
Fredericksburg Va
P
plycuda Offline OP
plycuda  Offline OP
P
Fredericksburg Va
i already did that. Just wondering if this actually gives the valve more clearance on the cylinder to improve flow.
Re: offset head dowels [Re: plycuda] #1118797
11/22/11 11:26 AM
11/22/11 11:26 AM
cincinnati ohio
mcat4321 Offline
mcat4321  Offline
cincinnati ohio
snake oil
Re: offset head dowels [Re: plycuda] #1118798
11/22/11 01:13 PM
11/22/11 01:13 PM
One of the blueprint things you can do is verify that the cylinder head is centered on the cylinder by mounting the head on the block with no crankshaft or pistons and rods in it and mark the cylinder diameter against the combustion chamber and then decide if you need to or want to move the head around on the cylinders (all four on that bank ) Castings vary Let us know what you find
Re: offset head dowels [Re: plycuda] #1118799
11/22/11 01:50 PM
11/22/11 01:50 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
To move the head enough to make a difference you would have to ream the head bolt holes to be able to bolt the head down after you moved it.
Getting old just means you were smarter than some and luckier than others.
Re: offset head dowels [Re: dannysbee] #1118800
11/22/11 10:10 PM
11/22/11 10:10 PM
Westbury, NY
bumps440 Offline
super gas
bumps440  Offline
super gas
Westbury, NY
Just do it. you may need to clearance the head bolt hole or not. will have to enlarge both the dowel hole in the head and block. very useful if you have big valves on a small bore. Like I am building. 2.25 intake on a 4.35 bore.
Realisticaly you might pick up a few CFM of flow.
if anything.... it wont hurt, for $12
