NOS Spark plug wire terminal ends. 70 E Body #1118393
11/21/11 03:10 PM
11/21/11 03:10 PM
Long Island, NY
70plymA34 Offline OP
Long Island, NY
I have been piecing together NOS plug wires for my 70 cuda 440-4 for a while now. Some have come with no terminals. Does anyone have a part number for the straight, 90 bent terminal ends or could they only be gotten with the wire sets. is there a close substitute??
i would like for it to look as stock as possible.
Re: NOS Spark plug wire terminal ends. 70 E Body [Re: 70plymA34] #1118394
11/21/11 03:15 PM
11/21/11 03:15 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
spark plug end or dist cap end?
Not sure about the spark plug ends, but I know you can get the dist cap ends thru most any auto parts supplier. made by standard if I remember right ( straights or 90's )
Re: NOS Spark plug wire terminal ends. 70 E Body [Re: gtx6970] #1118395
11/21/11 05:22 PM
11/21/11 05:22 PM
Long Island, NY
Long Island, NY
is there a difference between the bent ends on the distributor vs. spark plug side. I would need some of both if there are differences. Do you have the standard part #?? I should be more clear. i dont need the rubber boots just the brass terminals.
