Valve spring to rocker arm clearance #1118346
11/21/11 01:38 PM
11/21/11 01:38 PM
Mt. Vernon, Ohio
dartman366 Offline OP
Mt. Vernon, Ohio
seriously concidering replacing my w2/w5 erson rocker this winter with T@D's or Harlan Sharp's now come's the tricky part, my valve springs are 1.625 dia and most rocker companys only go up to a 1.550 spring, I was told that they can clearance them a little more but that also weaken's the rocker and I really dont want that issue, now the only other thought was to go to a smaller dia spring, I am not sure of the full open pressure but I do know they are 235# on the seat as I have a tester and do check them a couple time a season,,,my question is which way would you guy's go if this was your motor,,clearance the rocker's or smaller dia spring, if one is available at that seat pressure for the roller cam that I use.
Re: Valve spring to rocker arm clearance [Re: dartman366] #1118347
11/21/11 02:01 PM
11/21/11 02:01 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
How much cam?
Re: Valve spring to rocker arm clearance [Re: supercomp] #1118348
11/21/11 02:17 PM
11/21/11 02:17 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
.688 intake,.673 exhaust W/1.6 rockers,, also duration is 268/274 @ .050 with 108 lobe seperation.
Re: Valve spring to rocker arm clearance [Re: dartman366] #1118349
11/21/11 02:40 PM
11/21/11 02:40 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
You can use crane 96886-16 1.551 diameter. installed at 1.950 and have 257 seat and 687 open. We've had good luck with them on a B block with .688 lift.
Re: Valve spring to rocker arm clearance [Re: dartman366] #1118350
11/21/11 02:54 PM
11/21/11 02:54 PM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
Comp 999's are a good 1.55 tool steel spring as well.
8.30's @3400 lbs
Re: Valve spring to rocker arm clearance [Re: dartman366] #1118351
11/21/11 07:21 PM
11/21/11 07:21 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
hi dartman. check out isky. ur cam is just alittle smaller than mine. i have their 9995 springs with t&d rockers. u could us the 9985 also. all i had to do was to shim my stands up alittle to get the geometry rite. springs came with a dyno sheet too. stay safe, seeya.
Re: Valve spring to rocker arm clearance [Re: rickraw] #1118352
11/21/11 07:31 PM
11/21/11 07:31 PM
Guitar Jones Offline
My cam is just a little bigger also and I use a 1.56 spring with the HS 1.6 rockers and they clear fine.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Valve spring to rocker arm clearance [Re: rickraw] #1118353
11/21/11 07:35 PM
11/21/11 07:35 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
You're only talking a difference of .075" diameter OR .037" closer to the rocker. That's not likely to cause you any grief. My Harland Sharps clear my 1.55 springs by a good 1/8" (big block). And they will only come close when the valve is closed so "if" they needed clearancing the absolute most you'd have to take off would be .037 (or less). Personally I don't think it'll be an issue.
Re: Valve spring to rocker arm clearance [Re: Stanton] #1118354
11/22/11 01:01 AM
11/22/11 01:01 AM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
I have a set of k-motions that are sold by Brodix and come on their assembled small block heads. My cam has almost the same lift as yours with 1.6 rockers. The springs are 1.55,installed at 1.950 and are 240 lbs on the seat and about 570 lbs at full lift. No clearance issues at all with the T&D rockers on Indy 360-2s. I have .780 seal to retainer clearance at full lift. Hope everything works out for ya Bill -Randy
Re: Valve spring to rocker arm clearance [Re: b1dartsport] #1118355
11/22/11 01:12 AM
11/22/11 01:12 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
"Lift" is insignificant here. The rocker is closest to the spring and/or retainer when the valve is closed so installed height would be the only other thing that might impact the clearance.
Re: Valve spring to rocker arm clearance [Re: Stanton] #1118356
11/22/11 08:10 AM
11/22/11 08:10 AM
The lift figures were being quoted I believe as a form of comparrison for open and closed valve spring pressures in a 1.55 size.
Re: Valve spring to rocker arm clearance [Re: Guitar Jones] #1118357
11/22/11 03:25 PM
11/22/11 03:25 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
thats the way I understood it also, but I also understand that the clearance is most critical at the fully closed position and that my friend's is where I am having my issues, I am going to have to find a set of 1.550 springs that will give me 240 to 250 on the seat at an installed height of approx 2.020 ( cannot get the tip of my calipers between the spring and pocket of the head), untill I get the head's pulled and disassembled then this is my best guess, a 1.950 installed height may work also, these head's are seriously due for a freshen any way.
Re: Valve spring to rocker arm clearance [Re: dartman366] #1118358
11/22/11 03:31 PM
11/22/11 03:31 PM
Finland
Hessu Offline
Hessu  Offline
Finland
Re: Valve spring to rocker arm clearance [Re: dartman366] #1118359
11/22/11 08:11 PM
11/22/11 08:11 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The post started with the OP being concerned about clearance between the rocker and spring. Everybody seems gung-ho to spend his money on a new set of springs. MY POINT is that the size difference is minimal and should not cause any clearance issues. Hell, replace the rockers as intended and try them on the heads. If they contact the sping THEN change those.
Re: Valve spring to rocker arm clearance [Re: Stanton] #1118360
11/22/11 10:10 PM
11/22/11 10:10 PM
I agree but small blocks are considerably different than big blocks when it comes to the valvetrain and clearances. A 1.625 spring will not clear my HS rockers on my W5's. There is at most .010 between the the spring and rocker at 2.0 installed height with my 1.56 springs. Just saying.
