'68 Hemi 4-speed drivetrain ID stampings #1118248
11/21/11 12:15 PM
11/21/11 12:15 PM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hey gang..
Not sure if an all-encompassing question has been posed, but I didn't find exactly what I was looking for.
Car: '68 Hemi Charger R/T 4-speed
Topic: ID stampings
Question: We all agree for the most part, that in '68, the VIN of the car was stamped on the block on the driver's side upper bellhousing mating area with the bellhousing of either the 727 or 4-speed stamped the same. Now, on a 4-speed, was the pad that's actually on the gearbox get stamped with the partial VIN "8B******" as well?
Cheers,
Troy
Troy
Houston Mopar Connection Club
Re: '68 Hemi 4-speed drivetrain ID stampings [Re: hemi68charger] #1118249
11/21/11 12:32 PM
11/21/11 12:32 PM
Los Altos Hills, CA
Dans 68 Offline
Dans 68  Offline
Los Altos Hills, CA
If the transmission was stamped with the partial vin (not all '68's were), it would be on the raised pad on the side of the transmission.
Dan
Re: '68 Hemi 4-speed drivetrain ID stampings [Re: Dans 68] #1118250
11/21/11 12:56 PM
11/21/11 12:56 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Here's a Hemi example. Concerning non stamped examples, FWIW I've never seen an original 68 Hemi car that did not have a stamped pad.
Re: '68 Hemi 4-speed drivetrain ID stampings [Re: ScottSmith_Harms] #1118251
11/21/11 02:22 PM
11/21/11 02:22 PM
Houston, Tx
Houston, Tx
Thanks Scott...
To clear things up, the drivetrain was stamped with the partial VIN as opposed to the body panels being stamped with the VON in '68.
Troy
Troy
Re: '68 Hemi 4-speed drivetrain ID stampings [Re: hemi68charger] #1118252
11/21/11 02:36 PM
11/21/11 02:36 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Yes, on a '68 "performance engine" - the block & 4-speed (or 727) will have the last 8-digits of the VIN# (NOT the Shipping Order Number, S.O.#, that is stamped on the body).
Re: '68 Hemi 4-speed drivetrain ID stampings [Re: hemi68charger] #1118253
11/21/11 02:41 PM
11/21/11 02:41 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Correct, here is the VIN tag from the same car
Re: '68 Hemi 4-speed drivetrain ID stampings [Re: ScottSmith_Harms] #1118254
11/21/11 02:42 PM
11/21/11 02:42 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Here is the fender tag from the same car
Re: '68 Hemi 4-speed drivetrain ID stampings [Re: ScottSmith_Harms] #1118255
11/21/11 02:43 PM
11/21/11 02:43 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Here is the trunk lip body stamping from the same car. The core support number stamping matched but the engine was a replacement.
Re: '68 Hemi 4-speed drivetrain ID stampings [Re: ScottSmith_Harms] #1118256
11/21/11 03:03 PM
11/21/11 03:03 PM
Fairfield Maine
hemi4speed Offline
hemi4speed  Offline
Fairfield Maine
Sorry for robbing the thread. Scott what would be the date on my hemi box date of 0140
Re: '68 Hemi 4-speed drivetrain ID stampings [Re: hemi4speed] #1118257
11/21/11 03:10 PM
11/21/11 03:10 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
That sounds like a sequence number not the date, what are the 4 digits prior to those?
Re: '68 Hemi 4-speed drivetrain ID stampings [Re: ScottSmith_Harms] #1118258
11/21/11 03:15 PM
11/21/11 03:15 PM
Fairfield Maine
hemi4speed Offline
hemi4speed  Offline
Fairfield Maine
Try posting a picture no luck!
8B279428
PP8332356 0140
Re: '68 Hemi 4-speed drivetrain ID stampings [Re: hemi4speed] #1118259
11/21/11 03:18 PM
11/21/11 03:18 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
2356 WOW! January 9th 1968. Same date as the example I posted! Built only 44 transmissions appart
Re: '68 Hemi 4-speed drivetrain ID stampings [Re: ScottSmith_Harms] #1118260
11/21/11 03:19 PM
11/21/11 03:19 PM
Fairfield Maine
hemi4speed Offline
hemi4speed  Offline
Fairfield Maine
I notice that also we got to play the lotto with those #'s
Re: '68 Hemi 4-speed drivetrain ID stampings [Re: hemi4speed] #1118261
11/21/11 03:21 PM
11/21/11 03:21 PM
Fairfield Maine
hemi4speed Offline
hemi4speed  Offline
Fairfield Maine
Check out my fender tag SPD 424
Re: '68 Hemi 4-speed drivetrain ID stampings [Re: hemi4speed] #1118262
11/21/11 03:21 PM
11/21/11 03:21 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Just for kicks, what's your cars SPD and VIN sequence number?
Re: '68 Hemi 4-speed drivetrain ID stampings [Re: ScottSmith_Harms] #1118263
11/21/11 03:38 PM
11/21/11 03:38 PM
Fairfield Maine
hemi4speed Offline
hemi4speed  Offline
Fairfield Maine
Dash Vin# 225124
When I bought the car it had a 23 spline in it, I rebuilt the 18 spline I had under the bench, I guess I couldnt get much closer other than finding the #'s tranny. These 2 hemi cars passed by each other on the same line the same day!!
Re: '68 Hemi 4-speed drivetrain ID stampings [Re: ScottSmith_Harms] #1118264
11/21/11 03:58 PM
11/21/11 03:58 PM
Houston, Tx
Houston, Tx
Holy Mackerel Scott!!!
The pictures of the tag and VIN you posted are of the car my friend's interested in !!!!! He asked me what I thought about the car since I used to own a '68 Hemi Charger R/T (you remember the LL1 I had I'm sure). I have other pictures of it together
You know any more about the car? PM me....
Troy
Re: '68 Hemi 4-speed drivetrain ID stampings [Re: hemi68charger] #1118265
11/21/11 04:11 PM
11/21/11 04:11 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Re: '68 Hemi 4-speed drivetrain ID stampings [Re: hemi4speed] #1118266
11/21/11 04:15 PM
11/21/11 04:15 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
That's pretty darn cool! So, you are saying that you don't have the original numbers trans but the one you do have aligns perfectly with a different car with the very same SPD? What are the odds!
Re: '68 Hemi 4-speed drivetrain ID stampings [Re: ScottSmith_Harms] #1118267
11/21/11 04:17 PM
11/21/11 04:17 PM
Fairfield Maine
hemi4speed Offline
hemi4speed  Offline
Fairfield Maine
Thats correct Scott
