Re: W5 Heads, Edumacate Me....
[Re: Dragula]
#1116973
11/19/11 05:45 PM
11/19/11 05:45 PM
Posts: 20,627 in a cattle trailer down by th...
Guitar Jones
I found a good set for a good price and a guy wants my W2's so I am considering buying the W5's. What's needed for rockers, and intake?
Rockers are the same for W5's and W2's if yours have the offset shafts. Intake is the same bolt pattern but obviously the ports are different. I have a couple intakes single 4150 style.
Header bolt pattern is the wide space W2 style.
You will also need the china wall spacers because the ports are raised so the head is wider.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Dragula]
#1116975
11/19/11 11:41 PM
11/19/11 11:41 PM
Posts: 3,695 nc
emarine01
nc
[Re: 340RICK]
#1116978
11/20/11 07:57 PM
11/20/11 07:57 PM
Posts: 12,383 Taxes & Virus's R-US, NY
Dragula
W2 and W5 take same rockers.........Yes
I would not mess around with any intake but the INDY......all others would be inferior.
Would you go to W5's over W2's?
[Re: Dragula]
#1116979
11/20/11 08:02 PM
11/20/11 08:02 PM
Quicktree
heck just go buy the indy headed motor Bigs has for sale.
[Re: Quicktree]
#1116980
11/20/11 08:48 PM
11/20/11 08:48 PM
Dragula
I need the cubes...I have a brand new 408 W2 motor i just had line bored and installed a girdle on, and the W5 heads flow a little more than my W2 heads.
