looking for info for altered wheelbase frontend set-up #1116757
11/19/11 10:25 AM
11/19/11 10:25 AM
malvern, ohio
3
3ddart Offline OP
3ddart  Offline OP
malvern, ohio
friend has altered wheelbase a-body with a straight axle front end (says it steers hard) and would like to change it to a torsion bar set-up like chrysler did with th b-bodies.he's figureing on using a b-body torsion bar for the extra lenghth needed. any info out there to help us do this? thanks dave
Re: looking for info for altered wheelbase frontend set-up [Re: 3ddart] #1116758
11/19/11 11:08 AM
11/19/11 11:08 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
you didnt say what year or make so Im assuming its a 65 or 66 Dart
Re: looking for info for altered wheelbase frontend set-up [Re: smokinwoody] #1116759
11/19/11 11:13 AM
11/19/11 11:13 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
I know on the B bodies the rear was moved up `12" and the front K members 10"
I assume the same on the smaller A bodies...that can vary...some pictures I have...
Re: looking for info for altered wheelbase frontend set-up [Re: smokinwoody] #1116760
11/19/11 11:18 AM
11/19/11 11:18 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
Re: looking for info for altered wheelbase frontend set-up [Re: 3ddart] #1116761
11/19/11 01:15 PM
11/19/11 01:15 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Mancini Racing carries some kool books done for these cars, some with drawings....
Just my $0.02..
Re: looking for info for altered wheelbase frontend set-up [Re: 3ddart] #1116762
11/19/11 02:21 PM
11/19/11 02:21 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Too much caster can cause that.
What steering gearbox (ratio) is he using???
Has he thought about a shorter Pitman arm??
Re: looking for info for altered wheelbase frontend set-up [Re: Dean_Kuzluzski] #1116763
11/19/11 05:53 PM
11/19/11 05:53 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Pitman arm ratios and less positive caster,4 or 5 degrees on a straight axle will solve the problem.
If he wants to use the k-frame set up use the E-body torsion bars on the early A-bodys and move the attachment point forward of the trans cross member.You can reverse the bar socket and face it forward at the cross member also.
Re: looking for info for altered wheelbase frontend set-up [Re: Sinitro] #1116764
11/21/11 09:52 AM
11/21/11 09:52 AM
malvern, ohio
3
3ddart Offline OP
3ddart  Offline OP
malvern, ohio
sinitro: which books are you refering to? thanks, dave, and yes it's a 63 dart
Re: looking for info for altered wheelbase frontend set-up [Re: 3ddart] #1116765
11/21/11 10:30 AM
11/21/11 10:30 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
