Manual steering gear box leaking. How to fix? #1116563
11/19/11 01:48 AM
11/19/11 01:48 AM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I have a manual steering box that I want to put into my Barracuda. It leaks oil from the lower seal (leaks quickly). Anyone know if I can replace just the seal? If so anyone have the part number? Is it a difficult fix?
Re: Manual steering gear box leaking. How to fix? [Re: VITC_GTX] #1116564
11/19/11 02:05 AM
11/19/11 02:05 AM
The Sunny Shuswap
dodgefarmer Offline
dodgefarmer  Offline
The Sunny Shuswap
My sector shaft was wore out.
Randy
Re: Manual steering gear box leaking. How to fix? [Re: VITC_GTX] #1116565
11/19/11 12:01 PM
11/19/11 12:01 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I don't doubt that this would be an over-the-counter seal at any bearing supply. But I'd be reading a service manual before tearing it apart.
Re: Manual steering gear box leaking. How to fix? [Re: VITC_GTX] #1116566
11/19/11 03:21 PM
11/19/11 03:21 PM
Milwaukee
ToddP Offline
super street
ToddP  Offline
super street
Milwaukee
Rock auto sells a seal. less than $5.00
I use grease in my manual box. Mobile 1 synthetic wheel bearing. Tapped a couple of zerks into the sector shaft housing to add grease.
So leaking really isn't an issue.
I am sure it is eaiser to replace seal with the sector shaft removed,
but you might be able to pry the seal out with the shaft in place.
Re: Manual steering gear box leaking. How to fix? [Re: ToddP] #1116567
11/20/11 12:59 AM
11/20/11 12:59 AM
scratchnfotraction Offline
I filled mine with greese also no more leaks
Re: Manual steering gear box leaking. How to fix? [Re: scratchnfotraction] #1116568
11/20/11 01:56 AM
11/20/11 01:56 AM
I go w Ebergs' recipe of wheel bearing grease w gear oil. I've seen bare steel on units when I pulled the plug out that used heavy grease and just the gear oil can be too thin & leak out. Works for me
Re: Manual steering gear box leaking. How to fix? [Re: RapidRobert] #1116569
11/20/11 02:03 AM
11/20/11 02:03 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
What's the recipe? 50/50?
Re: Manual steering gear box leaking. How to fix? [Re: VITC_GTX] #1116570
11/20/11 02:16 AM
11/20/11 02:16 AM
Not 50/50. Let me see if I can find it. EDIT tube of Mopar wheel bearing grease 4318064 and 2 or 3 oz of 90 wt gear. heat it up in a pan on the stove to mix it & just enough gear oil so it's pourable
