Page 1 of 3 1 2 3
original 1971 340 Duster #1114006
11/15/11 01:07 AM
11/15/11 01:07 AM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
I just picked this car up a week ago and wanted to share it. it was listed here on moparts and also ebay for a while. its pretty much all original with the #'s matching drive train. most of the body is original with exception of the grill, drivers fender, bumper and hood paint due to the original owner hitting a pig with it in the late 70's. my plan is to correct a few issues with it and just drive it. I dont really think Im going to full on restore this one. it actually drives suprisingly nice. original options include hemi orange paint, blk vinal top, blk bench with center arm rest, side and tail stripe, duel exhaust with tips, tach, ralley wheels, light package and am radio. everthing works with the exception of the temp gauge. Ill post a few pictures. if anyone wants any specific shots, let me know. thanks!
-kevin
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: original 1971 340 Duster [Re: mopars_1] #1114007
11/15/11 01:09 AM
11/15/11 01:09 AM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
rear.. the original exhaust tips were taken off some time ago when a new system was put on. just some cheap generic tips now..
1937 Plymouth PT50
Re: original 1971 340 Duster [Re: mopars_1] #1114008
11/15/11 01:12 AM
11/15/11 01:12 AM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
interior is exceptionaly clean. a few small tears in the headliner is pretty much the extent of it. aftermarket radio under the dash and an extra temp gauge.
1937 Plymouth PT50
Re: original 1971 340 Duster [Re: mopars_1] #1114009
11/15/11 01:14 AM
11/15/11 01:14 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I'd like to see good engine detail pics.
Re: original 1971 340 Duster [Re: mopars_1] #1114010
11/15/11 01:19 AM
11/15/11 01:19 AM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
engine bay. some things have been changed, but I have the original parts such as the 4973 thermoquad, radiator, cap+ rotor. one thing missing is the fast idle solenoid.. lucky me
1937 Plymouth PT50
Re: original 1971 340 Duster [Re: mopars_1] #1114011
11/15/11 01:24 AM
11/15/11 01:24 AM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
original thermoquad
1937 Plymouth PT50
Re: original 1971 340 Duster [Re: mopars_1] #1114012
11/15/11 01:26 AM
11/15/11 01:26 AM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
original radiator. I probably will recore it and put it back in. also plan on rebuilding the thermoquad and putting that back in place
1937 Plymouth PT50
Re: original 1971 340 Duster [Re: mopars_1] #1114013
11/15/11 01:29 AM
11/15/11 01:29 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
What power options does it have? Does it have disc brakes?
Re: original 1971 340 Duster [Re: mopars_1] #1114014
11/15/11 01:30 AM
11/15/11 01:30 AM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
drivers side firewall/ inner fender. notice the yellow 'x' opposed to the blob. there is also another yellow 'x' between the washer bottle and firewall for some reason?
1937 Plymouth PT50
Re: original 1971 340 Duster [Re: ScottSmith_Harms] #1114015
11/15/11 01:32 AM
11/15/11 01:32 AM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
just power steering. standard manual drum breaks.
1937 Plymouth PT50
Re: original 1971 340 Duster [Re: mopars_1] #1114016
11/15/11 01:33 AM
11/15/11 01:33 AM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
drivers side top of motor.
1937 Plymouth PT50
Re: original 1971 340 Duster [Re: mopars_1] #1114017
11/15/11 01:34 AM
11/15/11 01:34 AM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
passnenger side shot
1937 Plymouth PT50
Re: original 1971 340 Duster [Re: mopars_1] #1114018
11/15/11 01:37 AM
11/15/11 01:37 AM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
power steering pump
1937 Plymouth PT50
Re: original 1971 340 Duster [Re: mopars_1] #1114019
11/15/11 01:41 AM
11/15/11 01:41 AM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
alternator
1937 Plymouth PT50
Re: original 1971 340 Duster [Re: mopars_1] #1114020
11/15/11 01:56 AM
11/15/11 01:56 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The most delicate details are the first to get lost in an engine clean up effort, stuff like chalk marks and ink stamps usually die first. It looks like you have a good opportunity to get some great details from your engine. The throttle cable had an ink date code stamping on the shiney silver ferral portion, IT'S VERY delicate and easy to wipe off, does yours still have it? Can you see any signs of a soft green paint daub there?
Some other questions:
What color is your throttle return spring?
Coil ink stamp date code?
Plug wire date codes
Heater hose part#'s/dates
Radiator hoses part#'s/Dates
Distributor date code?
Alternator casting dates/part#s/Date codes
Starter casting dates/part#s/Date codes
Carb Date code?
Fuel pump date code?
Temp sender date code?
Oil sender date code?
Power steering pressure hose date
Exhaust manifolds casting dates
Engine mount rubber casting dates (yes they have them!)
Any signs of paint on the negative battery cable?
What color is the dip stick handle?
That's just a start, please list all of the parts date codes as you can, many seemingly obscure engine componants have them, see my "Totally Anal 340 thread" for details if you aren't sure of of what to look for.
Re: original 1971 340 Duster [Re: ScottSmith_Harms] #1114021
11/15/11 12:03 PM
11/15/11 12:03 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Love your Duster!! What plant was yours built at?
Re: original 1971 340 Duster [Re: NV69B7RR] #1114022
11/15/11 03:12 PM
11/15/11 03:12 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
That's a neat Duster. If I ever do another car, it will be a 340 Duster or Demon.
65 Barracuda
70 Challenger
Re: original 1971 340 Duster [Re: ScottSmith_Harms] #1114023
11/15/11 06:14 PM
11/15/11 06:14 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
Carb Date code?
dont worry, Ive been on that thread probably a hundred times lol. I plan on getting all of the dates codes off the car. I want to take it to my nieghbor who has a car hoist. I hope to get around to it this weekend. also, I didn't plan on cleaning it up for that particular reason some of the stuff mentioned in your questions have been changed like motor mounts, fuel pump and radiator hoses. thanks!
-kevin
1937 Plymouth PT50
Re: original 1971 340 Duster [Re: mopars_1] #1114024
11/15/11 06:24 PM
11/15/11 06:24 PM
Washington
19cuda73 Offline
19cuda73  Offline
Washington
Nice Car what a find. Great car to restore
There is one for sale by me on craiglist I believe its a red car too and a 340
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: original 1971 340 Duster [Re: mopars_1] #1114025
11/15/11 08:28 PM
11/15/11 08:28 PM
USA
V
VS29H0B Offline
VS29H0B  Offline
V
USA
Carb Date code?
-kevin
This car looks like the car that was pulled out of a barn in Iowa earlier this year, by a guy who was more of a B body guy, and did some cleanup, drove it some, then put it up for sale on forabodiesonly.
Same car?
Like the women I have dated --- Always looking for a better deal ....
Page 1 of 3 1 2 3
