68 Bee inner/outer wheel tubs same for 2/4 door? #1112683
11/13/11 03:13 PM
11/13/11 03:13 PM
Austin, TX
HemiDave Offline OP
HemiDave  Offline OP
Austin, TX
Looking inside the trunk, are the 2 parts that make up the wheel tub the same on 2 door and 4 door cars?
Anything different in 69 from 68?
Thanks!!
Re: 68 Bee inner/outer wheel tubs same for 2/4 door? [Re: HemiDave] #1112684
11/14/11 12:34 AM
11/14/11 12:34 AM
New Jersey
myrddin Offline
myrddin  Offline
New Jersey
A quick look in the parts catalog tells me the inner are the same, while the outer will be different. 68-69 should be the same. Someone correct me if I'm wrong.
Re: 68 Bee inner/outer wheel tubs same for 2/4 door? [Re: HemiDave] #1112685
11/14/11 10:52 AM
11/14/11 10:52 AM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
the 4 dr inners are the same
the 4 dr outers are different
68-9 should be the same animal.
Re: 68 Bee inner/outer wheel tubs same for 2/4 door? [Re: flypaper] #1112686
11/14/11 02:35 PM
11/14/11 02:35 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
I don't know if it covers all B-body or if there is a difference between Dodge and Plymouth. I reversed a Mini-tub job on my 68 Road Runner a few years ago and the donor inners were from a 68 4 door Satellite and they worked perfectly - even the bracket to the trunk support lined up exact. I even discovered that the frame section I had to splice in must have been made on the same machine since all the small ripples around the curved section matched exact as well. In the picture you can tell that the donor car was green - aren't they all...
