advance or retard? #1111909
11/12/11 11:40 AM
11/12/11 11:40 AM
New Jersey, USA
Y
yella71 Offline OP
yella71  Offline OP
Y
New Jersey, USA
Thinking about resetting the cam in my 440 to get the cranking compression up. right now it's 135#.I felt that was a bit low. It has iron stage 4 heads that have un modified chambers with TRW 2295 pistons with stock crank and rods. the cam is a 528 mopar solid with the lash set at .020 in and ex.I think theres more power to be had in this combo. also im running a six pac that has acelorator pumps on all carbs. best et so far is 12.41 @106 Mph. Any thoughts?
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: advance or retard? [Re: yella71] #1111910
11/12/11 01:45 PM
11/12/11 01:45 PM
Do you know where the cam is installed at now as far as the intake lobe centers and the lobe seperation angle of the cam? If not on either figure that out first and post the results before you touch it BTW, what style, A, B, E or C body and year is the motor in? It matters as far as what else may be needed
Re: advance or retard? [Re: yella71] #1111911
11/12/11 02:44 PM
11/12/11 02:44 PM
Az
Crizila Offline
Crizila  Offline
Az
Do you know the CR. 135 is too low. Advancing the cam may help a very small amount, but it won't solve your problem. My guess is that the CR is way low.
Fastest 300
Re: advance or retard? [Re: Crizila] #1111912
11/12/11 02:57 PM
11/12/11 02:57 PM
New York
polyspheric Offline
polyspheric  Offline
New York
True, psi is too low to be fixed by advancing the cam. Needs more static CR, smaller cam (or at least earlier IVC).
Boffin Emeritus
Re: advance or retard? [Re: Crizila] #1111913
11/12/11 02:59 PM
11/12/11 02:59 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
Opening the intake lash to spec. should increase cranking pressure.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
