advance or retard?
#1111909
11/12/11 11:40 AM
11/12/11 11:40 AM
Posts: 1,406 New Jersey, USA
yella71
New Jersey, USA
Thinking about resetting the cam in my 440 to get the cranking compression up. right now it's 135#.I felt that was a bit low. It has iron stage 4 heads that have un modified chambers with TRW 2295 pistons with stock crank and rods. the cam is a 528 mopar solid with the lash set at .020 in and ex.I think theres more power to be had in this combo. also im running a six pac that has acelorator pumps on all carbs. best et so far is 12.41 @106 Mph. Any thoughts?
71 challenger convertable, 64 sport fury 383 ci with factory air
99 sebring convertable
89 CTD pup
Re: advance or retard?
[Re: yella71]
#1111911
11/12/11 02:44 PM
11/12/11 02:44 PM
Posts: 7,506 Az
Crizila
Az
Do you know the CR. 135 is too low. Advancing the cam may help a very small amount, but it won't solve your problem. My guess is that the CR is way low.
Fastest 300
[Re: Crizila]
#1111912
11/12/11 02:57 PM
11/12/11 02:57 PM
Posts: 4,205 New York
polyspheric
New York
True, psi is too low to be fixed by advancing the cam. Needs more static CR, smaller cam (or at least earlier IVC).
Boffin Emeritus
[Re: Crizila]
#1111913
11/12/11 02:59 PM
11/12/11 02:59 PM
Posts: 2,091 oberlin, Ohio
Rapid340
oberlin, Ohio
Opening the intake lash to spec. should increase cranking pressure.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
