Correct door trim location : E- body #1110594
11/09/11 11:36 PM
11/09/11 11:36 PM
KY
70cudaMD Offline OP
70cudaMD  Offline OP
KY
Adding the anodized aluminum trim pieces that are on the top of the door but doors don't have the studs for the clips. Would appreciate a pic of a door with the trim to see exact location and if possible a pic of the correct location of the studs (number of studs/distance between etc.) Thanks.
Re: Correct door trim location : E- body [Re: 70cudaMD] #1110595
11/10/11 01:07 AM
11/10/11 01:07 AM
Mississippi
lahatte Offline
lahatte  Offline
Mississippi
Re: Correct door trim location : E- body [Re: lahatte] #1110596
11/11/11 05:44 PM
11/11/11 05:44 PM
Maple Ridge, BC, Canada
Barnabas_Kriss Offline
I don't have a picture, but 70 did not use studs. On a 70 there are drilled holes, with clips that pop into the holes. 71-74's used the studs, with a different type of clip.
Re: Correct door trim location : E- body [Re: Barnabas_Kriss] #1110597
11/12/11 06:53 PM
11/12/11 06:53 PM
North America
2002bluert Offline
2002bluert  Offline
North America
Are you looking for Cuda trim or Challenger as I have pictures of Challenger trim clips and not sure if they are the same for Cudas. Sames as hole spacing I have pictures and measurements for Challenger. Let me know.
Re: Correct door trim location : E- body [Re: 2002bluert] #1110598
11/12/11 09:44 PM
11/12/11 09:44 PM
KY
70cudaMD Offline OP
70cudaMD  Offline OP
KY
cuda trim
Re: Correct door trim location : E- body [Re: Barnabas_Kriss] #1110599
11/12/11 09:45 PM
11/12/11 09:45 PM
KY
70cudaMD Offline OP
70cudaMD  Offline OP
KY
thanks
