Re: BOTTOM-END GIRDLE KIT???
[Re: BradH]
#1109463
11/11/11 05:22 PM
11/11/11 05:22 PM
Posts: 8,936 Holly/MI
Dean_Kuzluzski
Holly/MI
OK, so, horizontally, not vertically relative to the crank centerline.
I like the theory behind why splayed 4 bolt set-ups work.
[Re: Labratt]
#1109468
11/13/11 04:16 PM
11/13/11 04:16 PM
[Re: 69darthulk]
#1109469
11/13/11 08:13 PM
11/13/11 08:13 PM
Posts: 501 ONTARIO,CANADA
604 Hemi GTX
ONTARIO,CANADA
I used the kit from 440 source. Low deck making around 700hp and am very happy with how it's holding up. Had the machine shop set it up and line hone it. They were nice enough to mark the shims for when I reasembled it. http://store.440source.com/Main-Stud-Girdles/products/135/
Just wondering how the 440 source main girdle would work with aluminum main caps. I see he sell the kit, just wondering Kevin
[Re: BradH]
#1109471
11/14/11 12:59 AM
11/14/11 12:59 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Not being a machinist, I'm curious why you need to have the main caps align honed when switching from bolts to studs, considering the caps fit into the main registers and the hardware is just there to strap 'em down. Yeah, I know, that's an over-simplified view... but still.
IMO, The distortion issue of the extra torque value is minimal. The studs extra shank diameter vs the bolts shank diameter is what can kick the main registers out of skew. Ive seen it, you wouldnt think it could happen but it does.
The simple finger nail test will catch it. Now it catches , before it didnt.
Yeah, I know, thats's an over-simplified view... but still.
[Re: ]
#1109472
11/14/11 02:09 AM
11/14/11 02:09 AM
Posts: 12,339 somwhere
smokinwoody
somwhere
That BCR set-up is one STOUT looking piece!
That's the unit I have as well.
thats why I want one to replace the CRE unit that I have...mine uses the stock caps...I want the extra beef and I like the main caps going web to web adding to the rigidity..
[Re: rowin4]
#1109473
11/14/11 11:53 AM
11/14/11 11:53 AM
Posts: 4,066 Mo.
racerx
Mo.
heres a pic of BCR's girdle/main caps assembly
It's such a nice piece it's a shame to cover it up with the oil pan.
That is a pretty piece wonder what that setup would cost ya.
[Re: joshking440]
#1109475
11/14/11 12:20 PM
11/14/11 12:20 PM
Posts: 4,066 Mo.
racerx
Mo.
If i remember correctly I paid around 850 dollars for the main caps and girdle but I could be off a few bucks
That is a nice pease..but if i was to do another bullet i'll just in vest that 850.00 in a new block.Speaking of blocks any testing made with the new b-block yet
