2nd gen charger trunk floor install.
#1109202
11/08/11 02:37 AM
11/08/11 02:37 AM
Posts: 1,523 Oakley CA
69charger440_6pa
Oakley CA
I'm looking for pics and info on trunk floor replacement on a second gen charger. I am working on installing a AMD trunk pan and am having issues getting the rear lip to line up where I need it without making a huge gap at the wheel housings. Has anyone else had this issue?
Thanks.
1969 Charger R/T under construction 2014 Ram 3500 Cummins 2006 Corvette Z06 2015 Corvette Z06 2014 BMW M5
Re: 2nd gen charger trunk floor install.
[Re: 69charger440_6pa]
#1109205
11/08/11 02:19 PM
11/08/11 02:19 PM
Posts: 18,157 Mass
DAYCLONA
Mass
I've installed the AMD trunk floor in the 2nd gen Charger, no issues with the floor, just the trunk extentions, they needed a little trimming/modification to fit, no biggy, the fit of the trunk floor was good, but you did need to "stretch" the wells by clamping the piss out of them to close up all the seams/gaps, ....but in the end the fit/finish was very good
How much did you have to pull in the wells? If I locate the rear lip where it needs to go then I have about 1/2-5/8" gap at the wells. I can pull it in with clamps but it seems to distort the outer well and I then worry about quarter panel fit problems.
I probally had to "stretch" them about 1/4" to close the gap up, if your gap is that much larger (1/2-5/8") I'd rather push the pan forward and close up the wheel house mating edges, and then "play" with the gap at the rear, you could add a flange, once welded ground, and seam sealed you wouldn't know, just make sure the rear of the car is where it needs to be, before welding stuff in
[Re: DAYCLONA]
#1109206
11/08/11 04:43 PM
11/08/11 04:43 PM
69charger440_6pa
Oakley CA
Ya that's probably what I'll have to end up doing. Thanks!
#1109207
11/09/11 03:01 AM
11/09/11 03:01 AM
69charger440_6pa
Oakley CA
Well I went ahead and extended the pan 1/2" and now everything fits great. Now it lines up with the quarter cap. Weld ground down.... Can't even tell.
