340 Question #1109000
11/07/11 10:12 PM
11/07/11 10:12 PM
Warrenton, VA
RoadRunnerJD Offline OP
Warrenton, VA
Where are the negative battery cable and the body ground strap attached to the motor? I thought I'd remember but now I'm not sure?
Re: 340 Question [Re: RoadRunnerJD] #1109001
11/07/11 10:19 PM
11/07/11 10:19 PM
ill
dennismopar73 Offline
ill
mmm , i thought they went to the front bolt on the front of the left head for the batt and the back of right head for the ground strap??
go look make sure??
Re: 340 Question [Re: dennismopar73] #1109002
11/07/11 10:24 PM
11/07/11 10:24 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
go look make sure??
Floyd Lippencott IV
Re: 340 Question [Re: mr_340] #1109003
11/07/11 10:54 PM
11/07/11 10:54 PM
ill
ill
I looked at the 70 duster and 71 rr and that is where they are at.
Re: 340 Question [Re: dennismopar73] #1109004
11/07/11 10:56 PM
11/07/11 10:56 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
What model year?
Re: 340 Question [Re: Alaskan_TA] #1109005
11/07/11 11:11 PM
11/07/11 11:11 PM
Warrenton, VA
Warrenton, VA
What model year?
It's a 69 Barracuda
Re: 340 Question [Re: RoadRunnerJD] #1109006
11/07/11 11:48 PM
11/07/11 11:48 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Negative battery cable gets bolted to the front of the driver's side head. The fire wall ground cable gets bolted to the rear of the passengers side head.
Re: 340 Question [Re: 69Cuda340S] #1109007
11/07/11 11:51 PM
11/07/11 11:51 PM
Warrenton, VA
Warrenton, VA
Thanks guys! I just wanted to double check
