Under Body and Chassis Colors #1107522
11/05/11 11:43 AM
11/05/11 11:43 AM
Ia
4spdana Offline OP
4spdana  Offline OP
Ia
helping a friend re-build his 68 GTX that's been sitting in a shed for 10 - 15 years.
he wants a basic or average rebuild of the car, not a all out resto.
staying with the factory silver color, engine compartment is painted, engine the correct color,pulled the 8-3/4 out and hot tanked it and backing plates. will wire wheel under side of body, should that be a body color, or a semi-gloss black, or should i use a under coating of some sort? springs,and housing ,semi-gloss?
needs a gas tank, just eave it natural?
is there post i could find some examples on?
Re: Under Body and Chassis Colors [Re: 4spdana] #1107523
11/05/11 02:37 PM
11/05/11 02:37 PM
michigan
70 buzz Offline
70 buzz  Offline
michigan
primer with over spray of body color
Re: Under Body and Chassis Colors [Re: 70 buzz] #1107524
11/05/11 07:10 PM
11/05/11 07:10 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
If you're going to strip the underside, might as well refinish it like original, unless the guy wants it "hopped up": that means a medium grey color (unless it's an L.A.-built car, they were flattish black), with body color overspray from spraying the lower perimeter of the car, and then undercoating in the wheelhousings. If the car had factory undercoating, that's another option of course. Looks like the rad support is already blacked out.
