any problems fitting amd 68 charger quarters? #1107103
11/04/11 05:28 PM
11/04/11 05:28 PM
Southeastern Ohio
1st_charger Offline OP
Southeastern Ohio
I'm working on my project 68 charger and going to be hanging a passenger side full quarter from amd. I'm just wondering if anyone on here had done this and if so did you run into any problems or was it almost a drop on!
Re: any problems fitting amd 68 charger quarters? [Re: 1st_charger] #1107104
11/04/11 09:56 PM
11/04/11 09:56 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I installed a set of AMD 69 Charger full qtrs, just like installing NOS sheetmetal.....just a FYI, before tacking in the rear tail section where the pot metal cap fits on the rear qtr tail, check the fit of the potmetal cap with the qtr, you might want to "massage" the outer shape somewhat as you clamp and tack into place to fit the endcap profile.
Mike
Re: any problems fitting amd 68 charger quarters? [Re: 1st_charger] #1107105
11/04/11 10:42 PM
11/04/11 10:42 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
hopefully you can look them over before you buy them
i've seen some at carlisle that had more ripples on them then the atlantic ocean ..
i was shocked when the buyer accepted them from stephens
Re: any problems fitting amd 68 charger quarters? [Re: DAYCLONA] #1107106
11/04/11 10:42 PM
11/04/11 10:42 PM
Canada
demon Offline
demon  Offline
Canada
Mike
I agree. I've installed AMD Charger 1/4's. Very good fit. The contours and gaps were right on. Only a couple things to watch for. The lower body line that runs from the wheel opening to the rear valance corner is sharper than original. I simply dollied it to a softer contour. Easily done before installing. There were some ripples near the rear window opening too but no biggie since it needs lead or filler anyway to blend to the roof so really a non issue there. Overall an excellent part.
A few recommendations I would have for anyone replacing 1/4's on any car is this. If you aren't experienced in panel replacement and bodywork, it's probably best left to the professionals. This is a major part of the car and correct installation is an absolute must.
Also I would suggest that if the roof lead is nice, and there is no rust around the rear windo or in the trunk opening, then the 1/4 skins are probably a better choice. Same quality part but no need to disturb the factory lead at the roof and not as intrusive since the upper part is left undisturbed. Less chance of screwing it up.
Yes there is a 7 foot butt weld, however with experience that becomes easy and almost undetectable if done well. The AMD panels are thick so butt welding is a breeze compared to the old thin skins that we had to use for 20 years.
Re: any problems fitting amd 68 charger quarters? [Re: demon] #1107107
11/05/11 09:31 AM
11/05/11 09:31 AM
Southeastern Ohio
Southeastern Ohio
Thanks for the tips everyone! I already have one quarter just dont have the area ready to test fit the quarter yet thanks again for the few things to watch for!
