Iginition for Hemi...help. #110626
08/26/08 12:25 PM
08/26/08 12:25 PM
Fairfield Maine
hemi4speed Offline OP
Fairfield Maine
Okay, I want it to look authentic..but the best performance, The dual points isnt putting the full potential to the pavement. What is out thier for eletronic systems the will give the best of both worlds..performance and look correct?
Re: Iginition for Hemi...help. [Re: hemi4speed] #110627
08/26/08 12:28 PM
08/26/08 12:28 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If it's not putting it's full potential to the pavement it's not set up right .
As far as STOCK look , a pertronics inside the stock dist housing or an ELECTRONIC pickup installed in the stock housing connected to an MSD box HIDDEN out of sight .
Re: Iginition for Hemi...help. [Re: hemi4speed] #110628
08/26/08 12:37 PM
08/26/08 12:37 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
i have cast iron prestolites dists with mopar elec pickups, msd box under dash. all stock componets on firewall with dummy harness. fools the best of them. they all come up at shows and say you still use mechanical charging?,stock ballast?stock coil? its msd coil painted black and lettered,and all elec charging under dash also. i just say oh ya its all stock and spins 7.5k just like that
MOPAR OR NO CAR
Re: Iginition for Hemi...help. [Re: hemi4speed] #110629
08/26/08 02:40 PM
08/26/08 02:40 PM
what are the symptoms that are telling you that there is more on the table that could be had?
Re: Iginition for Hemi...help. [Re: RapidRobert] #110630
08/26/08 04:57 PM
08/26/08 04:57 PM
Fairfield Maine
Fairfield Maine
It dynoed @502hp with msd/electronic distributor,
I'm running a Mallory dual point distributor in the car. It seems to pull well, somtimes it starts breaking down at higher Rpm. I have the points set at 17. and running a stock coil,using firecore 50 plug wires with autolite 85.(full timming is set at 36*.)
Re: Iginition for Hemi...help. [Re: hemi4speed] #110631
08/26/08 05:50 PM
08/26/08 05:50 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
I ran Mallorys for years and its a good distributor. Try and get it on a dist machine and set the dwell. Remember 3K on the machine equals 6K on the engine. If I remember right dwell should be around 35, a lot more accurate than point gap. Also the machine will show if your getting point bounce which could occur, I just bent the springs out to add a little more tension when I put a set in. I've heard of the dist cam lobe wearing down and causing a problem but I've never seen it, thats why they give you that little pill full of grease when you get new points, to grease the cam lobes.
