66-67 B body tail pipe hangars #1106223
11/02/11 08:28 PM
11/02/11 08:28 PM
Pennsylvania
hemi67 Offline OP
hemi67  Offline OP
Pennsylvania
How do the rear most tail pipe hangars on a 67 b-body with a hemi attach to the frame?? I see a square and round hole in that vicinity in the frame but don`t have the hangers yet. Just ordered a complete system from Accurate Exhaust and Im trying to make sure I am ready when it arrives. these round holes are not threaded nor do they have a nut attached on the top side.
thanks.
Re: 66-67 B body tail pipe hangars [Re: hemi67] #1106224
11/02/11 08:36 PM
11/02/11 08:36 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Usually the square or rectangular hole is for a locating tab, with the round hole being for the fastener. Pretty sure the fastener would be 5/16-18 thread, likely self-tapping if there's no nut welded inside the rail, but if you see what looks like a square plate behind/inside of that hole, that's for a self-tapping bolt.
I have a pair of tailpipe hangers for a'67 GTX; don't know if they're the same for Hemis & 440s.
Re: 66-67 B body tail pipe hangars [Re: topside] #1106225
11/03/11 12:11 AM
11/03/11 12:11 AM
Howell, Michigan
Hemidavey Offline
Hemidavey  Offline
Howell, Michigan
My car has j bolts in the frame and 5/16 bolts going straight up into them.
Re: 66-67 B body tail pipe hangars [Re: Hemidavey] #1106226
11/03/11 07:36 PM
11/03/11 07:36 PM
Pennsylvania
hemi67 Offline OP
hemi67  Offline OP
Pennsylvania
Beautiful car!!. What do you mean by J bolts?? Are you talking about the kind that slide over the hole and have a threaded attachment like what you see on fenders and body parts??
Re: 66-67 B body tail pipe hangars [Re: hemi67] #1106227
11/03/11 08:48 PM
11/03/11 08:48 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
Maybe someone can pOst a detail from the service manual? If the attaching nut is not welded on the inside if the side of the frame it may be on the bottom if the frame. I don'thave a67 but my tip hanger hooks into the hole in the side of the frame and the bolt screws into a threaded insert in the bottom if the frame. It will be pretty obvious when you get your parts
Re: 66-67 B body tail pipe hangars [Re: hemi67] #1106228
11/03/11 11:00 PM
11/03/11 11:00 PM
Howell, Michigan
Hemidavey Offline
Hemidavey  Offline
Howell, Michigan
yes same type of fastener as a fender.
Re: 66-67 B body tail pipe hangars [Re: hemi67] #1106229
11/04/11 04:32 PM
11/04/11 04:32 PM
Roseburg, Oregon
Tom Swope Offline
Tom Swope  Offline
Roseburg, Oregon
This illustration might help. Anytime there is a question on how to install our products you can e-mail or call anytime for specific information.
Re: 66-67 B body tail pipe hangars [Re: Tom Swope] #1106230
11/04/11 07:03 PM
11/04/11 07:03 PM
Pennsylvania
hemi67 Offline OP
hemi67  Offline OP
Pennsylvania
Great! Many thanks for your help. The picture is exactly what I needed to see. This is a 16 year project that is finally approaching completion.
thanks again
santo
Re: 66-67 B body tail pipe hangars [Re: Tom Swope] #1106231
11/04/11 11:57 PM
11/04/11 11:57 PM
Warrenton, VA
Warrenton, VA
Tom, is that for the tailpipe tip or the muffler?
Re: 66-67 B body tail pipe hangars [Re: RoadRunnerJD] #1106232
11/05/11 12:21 AM
11/05/11 12:21 AM
Roseburg, Oregon
Tom Swope Offline
Tom Swope  Offline
Roseburg, Oregon
Here is a picture of the 66-67 (148,149) B body tailpipe hangers installed. Muffler hangers are different and are located at the rear of the mufflers and bolted to the floor pan brackets.Here is the link that shows the diagram and location http://www.accurateltd.com/Hanger-B-body-Main-Support-Double-Loop-Design-D-737_p_127.html
