What spring perches should I look for? 8 3/4 #1105804
11/02/11 01:17 AM
11/02/11 01:17 AM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I need to get a set of perches for a 8 3/4. I keep thinking folks talked about a certain part number (smaller centering hole???) that I should get.
Are these the proper ones? http://www.summitracing.com/parts/DCC-4120074/?rtype=10
Re: What spring perches should I look for? 8 3/4 [Re: VITC_GTX] #1105805
11/02/11 03:06 AM
11/02/11 03:06 AM
Happy Birthday RapidRobert  Offline
I forget if the MP ones have the large or the small centering hole but you can cut a piece of round hard steel stock to reduce the ID on the large hole ones to 1/2" so the spring round nub will nestle perfect. Just dont know if there's a big difference in the quality between the two (IE the MP ones and the Moroso ones which iirc what I saw in Mancini's flyer)
Re: What spring perches should I look for? 8 3/4 [Re: RapidRobert] #1105806
11/02/11 06:37 AM
11/02/11 06:37 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
those will be fine on trucks, 72 and earlier B bodys and A bodys.. The 73 and newer Bs,and FMJ cars have the large hole...
I am truckless..
