Re-attaching loop bracket at bottom of glass frame arm? #1105356
11/01/11 07:46 PM
11/01/11 07:46 PM
U.S.
basik Offline OP
basik  Offline OP
U.S.
At the very bottom of a glass frame arm there is the little bracket with a loop on it - which I guess keeps the arm more stable once it's installed in the door. I'm thinking the frame arm and the bracket are both made out of pot metal? How can I re-attach the loop bracket back onto the arm?
Re: Re-attaching loop bracket at bottom of glass frame arm? [Re: basik] #1105357
11/01/11 10:56 PM
11/01/11 10:56 PM
U.S.
basik Offline OP
basik  Offline OP
U.S.
To update, I'm talking about the vent glass frame on a 1970 b body.
Re: Re-attaching loop bracket at bottom of glass frame arm? [Re: basik] #1105358
11/01/11 11:37 PM
11/01/11 11:37 PM
New Jersey
myrddin Offline
myrddin  Offline
New Jersey
If you mean at the very bottom, thats not pot metal but galvanized. I had a friend handy with a welder tack them back on. Worked great.
Re: Re-attaching loop bracket at bottom of glass frame arm? [Re: myrddin] #1105359
11/02/11 12:59 AM
11/02/11 12:59 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
I Mig / Tack welded mine back on, it was broken off.
Re: Re-attaching loop bracket at bottom of glass frame arm? [Re: sthemi] #1105360
11/02/11 10:43 PM
11/02/11 10:43 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
I Mig welded mine back on too.
Drill a hole in the bracket where each spot weld was. Then grind away some of the galvanizing surrounding the hole so you (or the guy welding it) aren't breathing the fumes when welding. Just plug weld with your mig and you're done.
Re: Re-attaching loop bracket at bottom of glass frame arm? [Re: Dave Watt] #1105361
11/03/11 12:14 AM
11/03/11 12:14 AM
Howell, Michigan
Hemidavey Offline
Hemidavey  Offline
Howell, Michigan
This is very common on B bodies, I fixed two of my cars as described above.
