Prepping metal & fiberglass for paint. Same? #1104987
11/01/11 12:26 AM
11/01/11 12:26 AM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
My race car has a glass nose and metal body. Mostly primer with some original paint showing through on metal, nose is glass with no primer/paint. Looking to complete my first/cheap paint job (Summit brand paint). How do I prep/primer the car to block and paint?
Re: Prepping metal & fiberglass for paint. Same? [Re: VITC_GTX] #1104988
11/01/11 01:06 AM
11/01/11 01:06 AM
OHIO
THE GLASS MAN Offline
OHIO
I always tell my clients to treat the fiberglass as if it steel. In other words sand and paint the fiberglass with the same products as you are using on the steel body.
Re: Prepping metal & fiberglass for paint. Same? [Re: THE GLASS MAN] #1104989
11/01/11 02:08 AM
11/01/11 02:08 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Thanks, I appreciate it.
I'll hit the entire car with epoxy primer followed by 2K then seal and base/clear.
Re: Prepping metal & fiberglass for paint. Same? [Re: VITC_GTX] #1104990
11/01/11 04:16 PM
11/01/11 04:16 PM
Carriere, MS
Flucus Offline
Flucus  Offline
Carriere, MS
prime and block sand with 180, prime and block with water sanding again with 320.
(add a little dish soap to you water to help keep paper from clogging as bad and keep the work area wet) spend the extra time and elbow grease on the blocking before sealing and u will b pleased with ur work
64 Barracuda 70 Duster 70 Dart 79 Warlock Truck 92 Dodge 150 05 Magnum
