VIN verification on small blocks, 1973 Challenger #1103151
10/28/11 12:08 PM
10/28/11 12:08 PM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hey gang..
Going to go check out a '73 340 Challenger for a friend who doesn't live in my neck of the woods. I'm familar with the body stampings on E-bodies, similar to the '71-'74 B-bodies. Are the '73's the same as the '71's? Cowl, trunk drip-trough? Anyone with a picture of the VIN machined area on a 340/small-block? Is it in the same place as the big blocks I'm accustomed to? Anything else in '73 I should focus on?
Cheers,
Troy
Troy
Houston Mopar Connection Club
Re: VIN verification on small blocks, 1973 Challenger [Re: hemi68charger] #1103152
10/28/11 12:21 PM
10/28/11 12:21 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
E-bodies were stamped on the cowl and radiator core support. No trunk drip-trough stampings on E-bodies.
Re: VIN verification on small blocks, 1973 Challenger [Re: 318 Stroker] #1103153
10/28/11 12:50 PM
10/28/11 12:50 PM
Houston, Tx
Houston, Tx
ool...
Anyone on the VIN stamping on the block? 340
Troy
Re: VIN verification on small blocks, 1973 Challenger [Re: 318 Stroker] #1103154
10/28/11 12:51 PM
10/28/11 12:51 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
And yes the block is stamped in the same area .
Re: VIN verification on small blocks, 1973 Challenger [Re: JohnRR] #1103155
10/28/11 01:11 PM
10/28/11 01:11 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
and the transmission
Re: VIN verification on small blocks, 1973 Challenger [Re: Morty426] #1103156
10/28/11 01:22 PM
10/28/11 01:22 PM
Houston, Tx
Houston, Tx
Thanks everyone..
Troy
Re: VIN verification on small blocks, 1973 Challenger [Re: hemi68charger] #1103157
10/28/11 10:05 PM
10/28/11 10:05 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Passenger side for the transmission too, on the bellhousing if it is an automatic & on the gearbox if it is a manual.
Re: VIN verification on small blocks, 1973 Challenger [Re: hemi68charger] #1103158
10/29/11 05:49 PM
10/29/11 05:49 PM
Houston, Tx
Houston, Tx
Thanks everyone....
Checked it out... The car's very nice....
Troy
