E body A pillar Trim Why are they different?
#1102541
10/27/11 12:39 PM
10/27/11 12:39 PM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
I was cleaning up my A pillar Trim today and noticed that the lower screw holes are not the same distance from the end. In other words, one is lower than the other. One of trim pieces is original to the car the other is one I bought a while back. Did the lower screw hole change at some point from 70-74? If so, I may have to find another one. I am not at my garage right now so I can't check to see if that is the way it is supposed to be but I'm thinking not.
Joe
65 Barracuda 70 Challenger
Re: E body A pillar Trim Why are they different?
[Re: burdar]
#1102546
10/27/11 03:45 PM
10/27/11 03:45 PM
Posts: 1,822 Colorado
denfireguy
Colorado
73 Challenger SPD 927 of 1972...only the lower holes are drilled. These are the original trim pieces. There is extra material around the upper holes but they aren't drilled.
Same as mine. November actual production date (day after Thanksgiving). I am thinking a 73-74 piece. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
