detailing dashes...... #1102304
10/27/11 01:12 AM
10/27/11 01:12 AM
Colorado Springs,Colorado
Roadrunner440-6 Offline OP
What's the recomendation for bringing back the white lettering on ....for example...the heater controls on a challenger. White paint.....white magic marker.?????? What do the pros do? Any help would be greatly appreciated. Thanks
Re: detailing dashes...... [Re: Roadrunner440-6] #1102305
10/27/11 09:38 AM
10/27/11 09:38 AM
Winnipeg,Manitoba
cudablues Offline
cudablues  Offline
Winnipeg,Manitoba
I used a paint pen.Got it from a hobby store
Re: detailing dashes...... [Re: cudablues] #1102306
10/27/11 10:47 AM
10/27/11 10:47 AM
thanks......I'll get one today.
Re: detailing dashes...... [Re: Roadrunner440-6] #1102307
10/27/11 02:37 PM
10/27/11 02:37 PM
Oakville, Ontario, Canada
CDN72SE Offline
CDN72SE  Offline
I've read that a lot of people use Testor's white model paint and a Q-tip or fine brush or toothpick for the lettering.
For the dash vent I uses a silver Krylon paint pen, came out good enough for me.
Re: detailing dashes...... [Re: CDN72SE] #1102308
10/27/11 03:00 PM
10/27/11 03:00 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
I used a paint pen like this from the Hobby or Craft Store and it is so easy and looks great. Just select the tip that will work best for what you trying to do. I used a flat tip or tapered tip for my lines and/or letters.
Good Luck, Joe
65 Barracuda
70 Challenger
Re: detailing dashes...... [Re: jrwoodjoe] #1102309
10/27/11 03:09 PM
10/27/11 03:09 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I also used a paint pen and it turned out perfect. I was worried there would be some pen strokes in the paint but there were none.
Re: detailing dashes...... [Re: burdar] #1102310
10/27/11 03:31 PM
10/27/11 03:31 PM
PA
BTTG Offline
BTTG  Offline
PA
For raised lettering this seems like it would work, but can the paint pens also be used on depressed lettering such as that on the e brake pull handle (i.e., is the pen tip thin enough to paint inside the lettering)?
Re: detailing dashes...... [Re: BTTG] #1102311
10/27/11 03:37 PM
10/27/11 03:37 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
For the E-brake handle I used Testors model paint. I brushed it into the recessed letters...let it dry and wiped the excess off the face of the handle with mineral spirits.
I did the same thing with the map light bezel.
Re: detailing dashes...... [Re: Roadrunner440-6] #1102312
10/29/11 04:51 PM
10/29/11 04:51 PM
None
71rm23 Offline
71rm23  Offline
None
Dont know if anyone has done this but I've used Testors white paint or equivalent and used the eraser of a pencil to apply it. Kinda like a stencil. Just get the eraser wet (not dripping) and press on to the lettering...perfect
Re: detailing dashes...... [Re: 71rm23] #1102313
10/30/11 06:05 AM
10/30/11 06:05 AM
Mississippi
lahatte Offline
lahatte  Offline
Mississippi
That is a great idea! Thanks!
