'01 Stratus Lower Ball Joint? #110200
08/25/08 06:29 PM
08/25/08 06:29 PM
IN
GTX4spd Offline OP
GTX4spd  Offline OP
IN
Anybody know about removing the lower ball joint? I had it in the press but it doesn't want to budge. I don't see a snap ring or any other retainer, but it feels as though something has it locked in place. The upper joint popped out quite easily but this one has me stymied. If anyone has the answer I'd certainly appreciate it!
Thanks!
Re: '01 Stratus Lower Ball Joint? [Re: GTX4spd] #110201
08/25/08 07:18 PM
08/25/08 07:18 PM
Wi.
old_racer Offline
old_racer  Offline
Wi.
to my knowledge on that model you have to replace the whole lower arm. Russ
Re: '01 Stratus Lower Ball Joint? [Re: old_racer] #110202
08/25/08 07:25 PM
08/25/08 07:25 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
I have an '02. Why didn't they put zerk fittings on those darn things?? There's not a greasable joint on that car.
Re: '01 Stratus Lower Ball Joint? [Re: GTX4spd] #110203
08/26/08 01:04 PM
08/26/08 01:04 PM
jamestown, ny
71scamp440 Offline
Hinged
71scamp440  Offline
Hinged
jamestown, ny
its the whole control arm you need. i work at a local parts store we sell mog and mevotech they both list whole arms not changeable joints. part # for left is k7425 # for right is K7427. hope this helps.
71 scamp big block with 915 heads 727 trans
