closed loop A/W #1101949
10/26/11 03:27 PM
10/26/11 03:27 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
i am going to try a closed loop into my engine radiator next with my air to water intercooler and have some an -16 welded into the radiator cross flow bee cool.my rad is a rt side top entry and left bottom outlet so i think the best place for the fittings is close to those hoses.
Re: closed loop A/W [Re: Clanton] #1101950
10/26/11 05:09 PM
10/26/11 05:09 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
Maybe I am reading it wrong - but you don't want 160°-200° heated engine water going thru the intercooler.
Re: closed loop A/W [Re: Duner] #1101951
10/26/11 05:30 PM
10/26/11 05:30 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
i understand your point.the air coming out of the blower is 270*F
Re: closed loop A/W [Re: Clanton] #1101952
10/26/11 05:37 PM
10/26/11 05:37 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
The air coming out of my turbo is 275° and I try and cool it with 40° water in the intercooler system - to end up with 90° air at the end of a pass. If I started with 200° water I would probably only see the IAT drop from 275° down to 250° since the intercooler cannot chill the air 100% to it's own temperature.
I don't think engine-temp water will cool the charge air at all.
Re: closed loop A/W [Re: Duner] #1101953
10/26/11 05:49 PM
10/26/11 05:49 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
the temp on the inlet side of the engine will be cooler where ther supply for the cooler will be.
i can add to the system a 12x13x1" before the pump to the cooler but after the rad.
Re: closed loop A/W [Re: Clanton] #1101954
10/27/11 01:53 AM
10/27/11 01:53 AM
IL.
4406RR Offline
4406RR  Offline
IL.
it will not be worth the time and money spent!!! get a electric water pump in line style and a fuel cell full of ice water will work a hundred times better
http://img.photobucket.com/albums/v390/jerggy13/c7374b0e.jpg
midamericacustoms.com lowering kit for the 72-93 dodge ram and ram charger 4406rr@gmail.com
Re: closed loop A/W [Re: 4406RR] #1101955
10/27/11 04:02 AM
10/27/11 04:02 AM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
Just plain bad idea....
Re: closed loop A/W [Re: 4406RR] #1101956
10/27/11 10:35 AM
10/27/11 10:35 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
ok Thanks everyone.i have been using a cell with ice or tap water[mostly tap water]i know the engine rad is not the best option but it is good to have other options sometimes.
