My build is coming to an end, now getting to the little parts. Like what size pulley on the blower! Have some questions on the supercharger. This is going in a 1998 Regular Cab Dakota Sport. Not going to see the track that much, just want something to have fun with on the streets.
I'm going to run a Novi 2000. I read the safe limit on these is 55000 RPM. I currently have a 7.25" crank pulley and a 3.25" pulley on the Novi.
So, 7.25"/3.25" = 2.23077
2.23077 x 3.54 = 7.89692
55000/7.89692 = 6965 RPM
This is going to be a street truck, I'm not going to spin it past 6000 RPM. I want this thing to last! So the way the Paxton is set up now, I can spin the engine all the way to 6965 RPM before over spinning the blower.
I was thinking a smaller pulley on the blower. Reason being, Paxton no longer makes a kit for the Dakota anymore. I read that there was a 8" crank pulley but mine came with the smaller crank pulley. I know a smaller pulley on the blower, the worse the belt slip will be, but I think a custom crank pulley would be $$$.
I'm going to get a Richard Racing pulley, once I know what size I need.
2.9" Pulley = 6215 RPM
2.85" Pulley = 6108 RPM
2.8" Pulley = 6000 RPM
I plan on setting the rev limiter at 6000 RPM and shift in the high 5000 RPM range. I'll try to pick a cam that accommodates this. Any suggestions for cams? I know, I know. I'm going to call cam companies and tell them my setup, but some of you might have real world experience with a similar setup. This is EFI, by the way.
So would I want to max out the blower where the rev limiter is to be on the safe side? Or is over spinning the blower not that bad? Again, I want the engine and the blower to last. I was thinking about the 2.8" pulley would be perfect, but what do you guys think?
Run down on the engine/transmission/rear.
360 Magnum block bored .030 over
Forged Eagle 3.58"
Forged Eagle I-beams 6.123"
Forged Probe SRS Pistons -14.5 cc
Total Seal Conventional Classic Steel Top piston rings - CS3690-35
ARP bolts
Felpro 1008 head gaskets
2.02 R/T heads 60.6 cc - no flow numbers yet, Kammers flow bench in Dayton is down at the moment.
Comp 1.6 roller rockers
Cam - only thing I haven't ordered, will do after I get flow numbers.
M1 2bbl
Spin-tech long tubes, 1 3/4" primaries and 3" collector.
F&B 52mm throttle body (Might be small, but I can change that after I get it running.)
Paxton Novi 2000
Compression ratio of the engine is 9.525:1
Viper T-56
Superior clutch
4.56 gears
Detroit true-trac
Shooting for 450-500 RWHP and 450-500 RWTQ, and very streetable. If the numbers go north of that, I wouldn't mind either, ha.
