What is best way to adjust lash on hyd roller cam? #1099851
10/23/11 10:39 AM
10/23/11 10:39 AM
Georgetown, TX
sc4579 Offline OP
sc4579  Offline OP
Georgetown, TX
What is the best way to ahjust my valve lash on a hyd. roller cam in my magnum motor. It has Edelbrock heads, 1.7 rockers, .501/.512 hyd roller cam. Should I adjust them hot or cold?
2023 Challenger Scat Pack 1320
2016 Jeep Renegade
Re: What is best way to adjust lash on hyd roller cam? [Re: sc4579] #1099852
10/23/11 10:47 AM
10/23/11 10:47 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
The best time is cold when you assemble the motor with intake manifold off. Only have to do it once and then forget about it.
Really can't do it right with the intake in place, got to be able to see the plunger in the lifter.
Good luck with those 1.7 rockers, better make sure the geometry is right.
Why 1.7 rockers? What's wrong with 1.5 which the heads were designed for?
