Using OEM steel shim head gaskets on a HEMI. is it OK? #1099519
10/22/11 09:10 PM
10/22/11 09:10 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Hi!
I am about to build the street HEMI for my original 1969 HEMI Charger and I was thinking about using some NOS steel shim head gaskets (NOS mopar) instead of the regular Fel Pro Gaskets to achieve some more compression.
Are these gaskets OK to use?
Any feedback on using them or against using them?
Also, whats the compressed thickness of these gaskets?
Domingo
Re: Using OEM steel shim head gaskets on a HEMI. is it OK? [Re: domingo] #1099520
10/22/11 09:24 PM
10/22/11 09:24 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Use them, .021 thick, they're good gaskets. Dave
Re: Using OEM steel shim head gaskets on a HEMI. is it OK? [Re: quickd100] #1099521
10/22/11 09:25 PM
10/22/11 09:25 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Yes...Copper spray them and then RTV the water holes.
Re: Using OEM steel shim head gaskets on a HEMI. is it OK? [Re: Dragula] #1099522
10/22/11 10:09 PM
10/22/11 10:09 PM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline
VanishPt  Offline
V
i use them on Stage V heads.
Re: Using OEM steel shim head gaskets on a HEMI. is it [Re: VanishPt] #1099523
10/23/11 05:44 AM
10/23/11 05:44 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Thanks! I will use em.
Re: Using OEM steel shim head gaskets on a HEMI. is it [Re: domingo] #1099524
10/23/11 12:23 PM
10/23/11 12:23 PM
detroit area
moderncylinder Offline
detroit area
aslong as you dont make too much power,, they are fine,, id say no issues to 800hp
the rocker gear tries to come off the head on a hami so you loose clamping load on the center 5 head bolts that go through the stands,, this will allow the head gaskets to blow if you make 800+hp,, there are ways to fix it,, but for you,,,, you should be fine
Re: Using OEM steel shim head gaskets on a HEMI. is it [Re: moderncylinder] #1099525
10/23/11 02:41 PM
10/23/11 02:41 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Thanks for the reply Jeff!!!
Yes, this is just a street build for my stock 69 HEMI Charger.
Its just been stroked to 477" and its getting a cam upgrade...other than that....its pretty much stock.
Im hoping for 550-600hp.
