questions for the e body folks #1099248
10/22/11 04:47 PM
10/22/11 04:47 PM
KY
70cudaMD Offline OP
70cudaMD  Offline OP
KY
1. bought some RPM from ECS for the front suspension parts, but what about the rear leaf springs. are they natural metal originally or painted black, Seen it both ways on cars at shows. Car is 70 hemi clone. 2. Does anyone make a decent set of wheel opening trim or is there just one supplier? The repops are junk. 3. I know the right side resonator hanger is welded on and painted and the left bolts on duel exhaust cars but is the left hanger painted or natural metal finish? Also if anyone has a pic of the hanger on the car that would be very helpful. Need to see exact location. Sorry so long winded but thanks for the help.
Re: questions for the e body folks [Re: 70cudaMD] #1099249
10/23/11 01:28 AM
10/23/11 01:28 AM
Mississippi
lahatte Offline
lahatte  Offline
Mississippi
Of all the cars I've delt with over the years, I've never seen any paint on leaf springs. Always complete rust.
Regarding the hanger, I believe it should be non-painted. I don't know what the original finish was. It may have been cad plated, but most originals I've seen are rusty.
Re: questions for the e body folks [Re: lahatte] #1099250
10/23/11 09:31 AM
10/23/11 09:31 AM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Re: questions for the e body folks [Re: 70cudaMD] #1099251
10/24/11 12:10 PM
10/24/11 12:10 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
The general feeling on posts on this board is that the ones from Dale's Cuda shop take the least amount of massaging to make them fit. Go to
https://board.moparts.org/ubbthreads/show...;gonew=1#UNREAD
and read what Darren did on his. Dennis is also doing one.
The only other alternative is $1000 NOS ones that surface every once in a while. I have a right rear one that I will use as a template to get the new ones to fit.
Craig
Craig
Re: questions for the e body folks [Re: denfireguy] #1099252
10/24/11 02:32 PM
10/24/11 02:32 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The DS bolt on hanger is bare metal. The new ones look like they come zinc plated. There are 4 indentations in the floorpan where you need to drill.
https://board.moparts.org/ubbthreads/upload2/4501928-Dsc05276-1.jpg
Re: questions for the e body folks [Re: 70cudaMD] #1099253
10/25/11 01:14 PM
10/25/11 01:14 PM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
How do you plan on using ECS on the springs? I am getting a new pair that are coming unpainted. Since there are plastic interleaves, not sure if I need to pull the springs apart. Also that would be the only way to get in between the springs with the ECS.
Re: questions for the e body folks [Re: njmopar] #1099254
10/25/11 01:22 PM
10/25/11 01:22 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
You'll have to pull the spring packs apart and heat each leaf separately.
Where are you getting new springs that come unpainted?
Re: questions for the e body folks [Re: burdar] #1099255
10/26/11 01:52 PM
10/26/11 01:52 PM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
This is for an a-body, but in talking with Detroit Eaton spring they will come unpainted (at least that is what she told me on the phone).
Re: questions for the e body folks [Re: burdar] #1099256
10/26/11 03:38 PM
10/26/11 03:38 PM
Houston Texas
PAINT IT BLACK Offline
Got a CHIP on my shoulder
Houston Texas
I believe Trans Am E bodys had black painted springs, but the others were natural.
People will tell you that the Dale's Cuda shop wheel opening trim is the best but THAT WAS NOT MY EXPERIENCE. The ones from Year One were the best. I THINK these are made by Metro, but I'm not sure. What I do know is that the rear trim from Dale's was completely unusable. They were INCHES off. Just buy from Year One first and if you aren't happy with them, their return policy is favorable. However, don't return them until you get another set in hand from whomever you try next. Seriously, I have an unusable set still here in my shop from Dale's. I couldn't believe how bad they were. Otherwise, my experiences with Dale's has been excellent.
Also, I wish I had known, but it is best to have the trim before you start on body work because your wheel openings can be massaged to work with your trim. These trim parts are the weakest point of my car. It doesn't have to be like this PG CLASSICS AND BE&A... you guys can SAVE us!
Re: questions for the e body folks [Re: PAINT IT BLACK] #1099257
10/26/11 10:24 PM
10/26/11 10:24 PM
KY
70cudaMD Offline OP
70cudaMD  Offline OP
KY
Thanks for the input on the wheel opening moldings. I already ordered a set from dales cuda shop, hope they are better than what I have. luckily my car is in primer and my resto shop is pre-fitting every piece of trim prior to paint. More money but definitely worth it in the long run.
Re: questions for the e body folks [Re: 70cudaMD] #1099258
10/27/11 08:10 AM
10/27/11 08:10 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
My customer brought me a set from Laysons this fall.
Most of the screw holes lined up with factory holes in the panels
Ft's went on fine with minimul work.
Rears however took a bit of massaging. And I had to make 2 small cuts in the flat part of the mdlg to get them to fit factory quarter panels.
Re: questions for the e body folks [Re: burdar] #1099259
10/27/11 11:35 PM
10/27/11 11:35 PM
Mississippi
lahatte Offline
lahatte  Offline
Mississippi
If you get a hanger that is zinc plated and you want it bare metal, make about a 50/50 mix of water and muriatic acid. Put the part in it until the fizzing stops. The zinc will be gone. Then, an application of the RPM (Rust Prevention Magic) might be a good thing.
