Re: MAX AIR PRESSURE IN M/T SPORTSMAN FRONTS???
[Re: MIKES_DUSTER]
#1098621
10/21/11 07:44 PM
10/21/11 07:44 PM
Triple Threat
Renton Washington
My 4 ply 26's were always above 40, usually 45+ Never an issue. I can tell you the car drive 100 times better with a radial on the front though.
[Re: Labratt]
#1098623
10/21/11 09:08 PM
10/21/11 09:08 PM
Posts: 728 mi usa
old yeller
mi usa
Bob..with a "heavy" car,you think 50 lbs. is safe? There's a warning on the side wall that says "tire could explode if inflated OVER 40 lbs"!!! Using bias-ply slicks...probably a good idea to stick with BIAS front tires!..MUCH MORE stable on the top end! Ask me how I know!
STABLE?, i go threw the traps @ 171 mph in the 1/4 mile and the roadrunner has weighed over 3,500lbs...with 50 lbs of front air pressure...i give up with you people!!!
[Re: tboomer]
#1098628
10/22/11 10:05 AM
10/22/11 10:05 AM
Posts: 2,177 ill
dennismopar73
ill
Randy...I run 36-37# in mine...Depends on reaction times..
I agree , track conditions, normal is @ 30-35#
