bolt on hydraulic clutch kits #1098593
10/21/11 04:24 PM
10/21/11 04:24 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
Im thinking about the one with hydraulic throwout bearing.
are there any true bolt ons avaliable for -68 a-body?
If so do they work?
Please educate me on them.
Pics would be great.
Re: bolt on hydraulic clutch kits [Re: sshemi] #1098594
10/21/11 09:34 PM
10/21/11 09:34 PM
Utah
topbrent Offline
topbrent  Offline
Utah
Re: bolt on hydraulic clutch kits [Re: topbrent] #1098595
10/22/11 04:47 AM
10/22/11 04:47 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
heres a pic of the small block 130 tooth hyd bell.
these come in the 88-91 pickups with the OD833. this would be the cheapest wat to go hyd in the A body.a different front bearing retainer woul be needed for use of a normal 833. I run a OD833 in my 340 powered 81 shorty and love it..
I am truckless..
Re: bolt on hydraulic clutch kits [Re: topbrent] #1098596
10/22/11 04:57 AM
10/22/11 04:57 AM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
i need some feedback from someone that has used one, if they are any good please.
Re: bolt on hydraulic clutch kits [Re: sshemi] #1098597
10/22/11 09:21 AM
10/22/11 09:21 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
After kicking and screaming, I finally went the totaly hydraulic route. I'll never go back.
Basically two choices on the T.O. bearing:
Timken and McLeod. Used both. Next time around I would go back to the Timken although their support is horrible. I got the impression that they were saying "we're really not Mopar guys, so..."
EDIT: I meant Tilton. Not Timken.
Re: bolt on hydraulic clutch kits [Re: Commando1] #1098598
10/22/11 09:30 AM
10/22/11 09:30 AM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
what clutch cylinder did you use?
Any part nr for the t/o bearing?
does anyone know the area of the piston in the t/o bearing so i can calc the needed clutch cyl area?
also what is the stock mec link ratio?
looked at the american powertrain kit and i really do not like the bracket for the clutch cyl witch they want 189$ for.
Re: bolt on hydraulic clutch kits [Re: 340SHORTY] #1098599
10/22/11 09:34 AM
10/22/11 09:34 AM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
i do not think i can find something like that here in sweden, besides i already have a blowproof bell.
And if i go hyd i really want the hyd t/o bearing
Re: bolt on hydraulic clutch kits [Re: sshemi] #1098600
10/22/11 09:56 AM
10/22/11 09:56 AM
IN
ahy Offline
ahy  Offline
IN
I have been running the Keisler hydraulic clutch setup on a TKO for over 5 years. I really like it and no problems to report. They advertise kits sold seperately. I know they have a kit for the TKO, not sure for the 833. It would be worth calling them.
Re: bolt on hydraulic clutch kits [Re: 340SHORTY] #1098601
10/23/11 03:07 AM
10/23/11 03:07 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Oh, Shorty! That is a rare bird you have there. According to the Haynes manual it's a one year only deal on the A833: 1987. I might be reading the manual wrong, so let me know.
Mo' Farts
Moderated by "tbagger".
Re: bolt on hydraulic clutch kits [Re: sshemi] #1098602
10/23/11 09:42 AM
10/23/11 09:42 AM
Commando1 Offline
Commando1  Offline
Master cylinder?
I used a late 80's - early 90's Nissan Pathfinder.
Less than 25 bucks and performs as good as a Wilwood.
Go to their websites.
Don't over complicate this area. A master cylinder with a 3/4"+ bore will work.
The instructions for clutch pedal throw come with the units. I believe they are also on their websites.
Re: bolt on hydraulic clutch kits [Re: Commando1] #1098603
10/24/11 04:11 AM
10/24/11 04:11 AM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
Do you mean a timken or tilton t.o.b ?
Re: bolt on hydraulic clutch kits [Re: sshemi] #1098604
10/24/11 08:52 AM
10/24/11 08:52 AM
Commando1 Offline
Commando1  Offline
Sorry about my brain fart. Them "T" companies all look alike.
My experience was with the TILTON 600 series. (A-833 = 61-617 Base assembly & 61-604 Hydraulic Assy) although I read that Timken has a hydraulic T.O. bearing.
http://www.tiltonracing.com/content.php?page=hydraulic2
Re: bolt on hydraulic clutch kits [Re: Commando1] #1098605
10/24/11 09:49 AM
10/24/11 09:49 AM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
is that for the large retainer bolt pattern? i think i read that somewhere. I have the small pattern witch is 3,7"
Also the 61-604 says it is for a 11" clutch, and i have the 10,5" clutch.
Another option might be the 400 series witch mounts to the rear inside of the housing, altough you need to drill those holes.
I dont understand this one if you need the bearing retainer or if you can use it without?
Re: bolt on hydraulic clutch kits [Re: sshemi] #1098606
10/24/11 12:03 PM
10/24/11 12:03 PM
Commando1 Offline
Commando1  Offline
is that for the large retainer bolt pattern....
I'm really not the go-to expert on this stuff. I was just sharing what I discovered through my own trial and error filled excursion into it.
If I was you, I would call tech support and pick their brains.
Re: bolt on hydraulic clutch kits [Re: Commando1] #1098607
10/24/11 01:51 PM
10/24/11 01:51 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
just got off the phone with Tilton techline.
He said the 400 series bearing is a bad idea because of the large retainer hole in the bellhousing, they are made for something like 4,6" hole and i have 4,8", i actually measured it and it would bolt up but the inner edge of the four mounting bosses would hang over the hole in the bell. Not a big problem to me but...
So i asked him if there are any other options avaliable for mopar and he said NONE.
Then why do they have the 600 series for Mopar?????????????
Im close to just stick with the stock linkage.
Re: bolt on hydraulic clutch kits [Re: sshemi] #1098608
10/24/11 02:04 PM
10/24/11 02:04 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
just got off the phone with keisler and they do NOT have a bearing for the a-833.
i think im gonna try the tilton 400 series anyway.
Re: bolt on hydraulic clutch kits [Re: sshemi] #1098609
10/24/11 04:00 PM
10/24/11 04:00 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
just calculated that if i use the 400 series bearing with a 3/4 master cyl it will be super close to the stock mec linkage ratio meaning that i probably can use the stock pedal mount.
Re: bolt on hydraulic clutch kits [Re: sshemi] #1098610
10/24/11 10:33 PM
10/24/11 10:33 PM
British Columbia
toddd Offline
toddd  Offline
British Columbia
I used the Mcleod hyd t/o bearing with "NO" issues or problems.
Re: bolt on hydraulic clutch kits [Re: toddd] #1098611
10/24/11 10:49 PM
10/24/11 10:49 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
American power train has what you need, just Google and click on mopar hydraulic clutch. I talked to these guy;s earlier this month about this set up, real easy to do, just a couple of measurements and bolt it up. Now the cost is not so easy for me, I'll stick to the old hardware.
Re: bolt on hydraulic clutch kits [Re: rowin4] #1098612
10/25/11 03:10 AM
10/25/11 03:10 AM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
I think the powertrain kit is a little expensive plus i dont like their master cyl bracket.
I ordered the tilton bearing and a wilwood master cyl.
I like the idea wirh the bearing att to the bellhousing.
For The bracket for the cyl i will fab something billet.
I also ordered a master cyl for a -98 camaro thAt looks like it could work, it was ok to return if it dont work
