Re: Stock mounts/K vs engine plate... Which is lightest..??
[Re: Pale_Roader]
#1098435
10/21/11 09:57 PM
10/21/11 09:57 PM
Posts: 43,123 Bend,OR USA
Cab_Burge
I have used elephant ears to install B,RB and 426 hemi in Dusters and Demons, I would bet money that you will save around 18 to 23 lbs by using them, especially if you cut all the stock mounts off of the K member I have two motor plates in the shop now on motors, I'll bet money there is not 3 lbs more weight in them than the eelepahnt ears They can be trimmed down a bunch also Now, Get after it
[Re: Pale_Roader]
#1098437
10/22/11 10:06 AM
10/22/11 10:06 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Hmmmmmm......
A 'few pounds' to 23lbs... give or take. That sounds like a worthy endeavor.
I'm assuming the general simplicity ov the install and maintenance on the engine is a lot better with a plate or ears...???
Any downsides to doing this...???
I would go with the engine plate... so much easier to get headers in... use a engine limiter also
[Re: TrxR]
#1098440
10/22/11 01:14 PM
10/22/11 01:14 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I didn't notice any difference from solid motor mounts to a plate.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1098441
10/22/11 10:00 PM
10/22/11 10:00 PM
MR_P_BODY
You wouldnt see any difference... both are solid
[Re: Pale_Roader]
#1098443
10/23/11 10:02 AM
10/23/11 10:02 AM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
A engine limiter stops or reduces the fore/aft movement of the engine.
If this was my car..I'd cut the mounts off of the stock 6 cyl K and use a plate.The plate makes engine removal/installation so much easier.
[Re: Pale_Roader]
#1098446
10/23/11 10:20 PM
10/23/11 10:20 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Ya, like there's a line a mile long waiting for that 6 cylinder k member. off the mounts.
[Re: Pale_Roader]
#1098447
10/24/11 12:53 AM
10/24/11 12:53 AM
Posts: 4,206 New York
polyspheric
New York
I'm not real happy with the aluminum plates in use. The danger is bending, and if 5/16" steel is enough, an aluminum plate has to be 15/16" for the same rigidity.
Boffin Emeritus
[Re: polyspheric]
#1098448
10/24/11 07:52 AM
10/24/11 07:52 AM
MR_P_BODY
Thats the reason for the engine limiters... even a 1/4" alum plate will handle the vertical load but as you said the fore/aft the plate would bend thus the limiters come into play... some just use the trans mount to control the fore/aft movement but on a hard launching car it'll tear that mount apart... I prefer the limiters... I use 2(one on each side of the engine) others use just one... another reason I prefer the limiters is, with just the rubber trans mount and the engine moves back it can/will bottom out the drive shaft into the trans creating a bind and the possibility of breaking the tail shaft on the trans
